Home > Puma (Tdci) > Rear Third Brake Light LED ? |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
Hello,
Is there any LED for the rear window lights to replace the OEM Brake light ? 2016 Defender 90 Adventure Edition |
20th Oct 2015 5:00pm |
Vehicle Glazing Specialists (formerly Landyglass) supplies EU approved LED rear glass LED lights. Maybe give him a call and see if he can provide you one or give details where you can get one from?
http://www.vehicleglazingspecialists.com/-90-products.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Oct 2015 6:24pm |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
This one from Hella also nice:
http://www.danielsternlighting.com/products/products.html http://www.thesamba.com/vw/forum/viewtopic...p;start=20 Saw the other day on a Land Cruiser a rear facing light bar mounted on the roof with LED main rear red lights, brake lights and indicators. With remaining space in middle for a LED work light bar. Did not get close enough to snap or see manufacturer name. All with clear lenses - but lighting up in the appropriate color - red/orange. Looked rather nice. |
21st Oct 2015 8:49am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
I think SFS is after something to put in the existing unit, rather than replacing it with another non-factory unit? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Oct 2015 9:01am |
exactly I want to replace OEM one 2016 Defender 90 Adventure Edition
21st Oct 2015 9:04am |
Great then I will wait for your products 2016 Defender 90 Adventure Edition
21st Oct 2015 1:48pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5110 |
I do not know if this is any help to you but I fitted one of these to my high level brake light very bright much better than the OEM bulb.
http://www.ebay.co.uk/itm/BA15S-12V-24V-PU...61rTZVxXrg For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
21st Oct 2015 3:15pm |
Waiting news......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
22nd Oct 2015 10:45pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Only 10 ish weeks left Pete for this Year
23rd Oct 2015 5:58am |
As seen on a Malaysia 110 double cab limited edition. This LED 3rd brake light would be an interesting one to install on a SW too, for instance on the upper door frame itself, or on the panel above, and same time replace the rear window by a version without the standard 3rd brake light with its incandescent bulb/holder.
Anybody have an idea which brand this LED brake light is? Eric Click image to enlarge Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
22nd Nov 2015 6:36am |
I like that but it's a bit extreme having to take the canopy off to make functional.
22nd Nov 2015 11:37am |
I would prefer to have OEM style 2016 Defender 90 Adventure Edition
22nd Nov 2015 2:55pm |
Any updates ? 2016 Defender 90 Adventure Edition |
22nd Dec 2015 4:59pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I fitted the LED bulb as above, quick fix and effective. Had to swop the two wires over, as LR had the polarity different. All simple stuff.
I also fitted a flash unit, which gives 5 flashes before coming on hard. There is an override in case of MOT problems. With the LED it is very distinctive and (hopefully) safer. Merlin |
23rd Dec 2015 11:38am |
