Home > Maintenance & Modifications > RedBooster Clutch Servo
Installed RedBooster and had issues with the clutch?
Yes I had issues with the clutch post installation
0%
 0%  [0]
I did not have any issues
0%
 0%  [0]
Clutch plate wore out prematurely
0%
 0%  [0]
Highly recommended; cant live without it
100%
 100%  [4]
Total Votes: 4
Arsath
United Arab Emirates 2010 Defender 110 Puma 2.4 CSW Fuji White
Hi
I am looking to install the Redbooster clutch servo, some of the defender owners I spoke to were telling me that this could wear out the clutch plate prematurely. some other were saying it reduces clutch performance (not sure what they meant by that). What do you guys suggest?
Post #462535 12th Oct 2015 12:10pm
shaggydog
Sounds like rubbish to me, all it does is make the clutch lighter by providing vacuum assistance the same way your brake system does.
I have no experience of one as I love my heavy clutch but I see no reason why it should wear your clutch out any quicker unless you slip it more due to it being lighter in operation? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #462541 12th Oct 2015 12:37pm
Ranger
United Kingdom 2003 Defender 110 Td5 G4 LE Zambezi Silver
Post #462560 12th Oct 2015 2:48pm
Cupboard
What's the "spring mod" that's talked about in that thread?
Post #462888 13th Oct 2015 1:43pm
shaggydog
You can change the clutch spring for a Td5 clutch spring which is much lighter than the older style Tdi clutch spring.
Have a look at your clutch peddle, if it has a long tubular spring coming down from a bolt to your peddle, you should be able to change it, if you don't then you probably already have the lighter version. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #462994 13th Oct 2015 8:04pm
We've sold several Red Booster kits and only had good feedback.
We had one on our TD5 tray back and it made winch challenges a lot easier on the left leg
Post #463023 13th Oct 2015 9:11pm
JustStarting
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Barolo Black
Hi Arsath
I have just had a Redbooster fitted on a TD5 Twincab that I use for off roading
I cannot praise it enough, the clutch is so light that after a full day off roading instead of my leg being tight and tired it was absolutely fine.
I have to admit that you need to get used to it and that you cannot rest your foot on the clutch at all else it will ride the clutch and slip
It took me a day to get used to it and it is money well spent.
Not sure I would fit it to my Puma but a definite for the tdi and td5 MY2015 110 Urban Truck Expedition Spec
2005 Td5 TwinCab
1998 110 CSW 300tdi
Post #464815 19th Oct 2015 10:30pm
Arsath
Thank you all for your valuable feedback.. I think I will do this upgrade..
Post #465459 22nd Oct 2015 12:18pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
I had looked into it but the cost for the unit plus for the install costs made it cost prohibitive for me and so just got used to the clutch Whistle and invested the money on other land needs.
Post #465470 22nd Oct 2015 12:44pm
