Home > Technical > A rear chassis roll bar question
razz
2001 Defender 90 Td5 PU Caledonian Blue
Hello , I'm gonna be fitting a ful roll bar kit , at the front I have the 2 bolt fixing plate on the chassis , at the rear I have as the picture shows , the rear section has been replaced at some point , what do I bolt to the shown plate to give me a flat plate to bolt the roll bar too please , ignore the brake calliper , she gets new rear brakes Monday Smile calipers , discs , pads n pipes but that another story , cheers
Post #464101 17th Oct 2015 6:04pm
Fatboy Slim
Wales
That's the tow bar mounting.
Post #464116 17th Oct 2015 7:16pm
razz
Cheers , another bit learnt . I see some weld on brackets , so will get them ordered with the roll bar , cheers ady
Post #464129 17th Oct 2015 7:52pm
George G
You will need to remove the tow bar brackets to fit the weld on ARB brackets as they sit in roughly the same position. Thumbs Up
Post #464213 17th Oct 2015 11:18pm
roel
I can send you a file with info how North offroad connects their cage to the chassis. Send me a pm with your email adress.
 Roel
2003 90 Td5 (2009-now)
Post #464221 18th Oct 2015 12:29am
razz
http://www.extreme4x4.co.uk/acatalog/DEF_9...CKETS.html
thanks everyone , so these brackets are for the tow bar and anto roll bar , so if i out them in the same place as my tow bar brackets , i can`t be far out . will check with roll bar first , cheers ady
Post #464284 18th Oct 2015 12:34pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Just a thought, if you do any green laning or off roading, I'd be inclined to leave the anti-roll bars off.
I took them off my TD5 HT and the ride was so much better and the articulation is great. It made little to no difference to the on road behaviour but miles better once you leave the tarmac.
Just my 2c Thumbs Up
cheers
simon
Post #464323 18th Oct 2015 2:39pm
mikeh501
Xeng do a roll bar which can be disconnected.
Post #464330 18th Oct 2015 2:57pm
razz
cheers everyone , i`ll have a play n see what i think , i can fit the front easily enough , so may get one to try , if it don`t feel any different , i`ll not worry about the rear , ady
Post #464717 19th Oct 2015 6:24pm
Screbble
Didn't want to start a new thread as this is really 'tenuously' related....
I'm having a bit of a runaround trying to source new rear ARB bushes for my std 90 XS.
The rear ARB on my truck is 19mm diameter.
I've ordered rear ARB bushes from two suppliers and they've both sent me front bushes. Well let me accurately present the facts. I actually ordered rear ARB bushes but those sent were for a 25mm ish ARB and they have a larger overall dimension. I checked them against the front and guess what - a perfect fit. As its a quick job I've now fitted them (to the front!) so no real lives lost - although I've got a spare set.
I'm just perplexed. For both suppliers to send me the same thing (25mm) I'm wondering if I have a non standard rear ARB???
Any pointers/guidance.
Please don't ask why I ordered two sets - it's a long story! I just want the right bushes........
Cheers,
Will
Post #464738 19th Oct 2015 7:31pm
