Home > Technical > A rear chassis roll bar question |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
That's the tow bar mounting.
17th Oct 2015 6:16pm |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
Cheers , another bit learnt . I see some weld on brackets , so will get them ordered with the roll bar , cheers ady
17th Oct 2015 6:52pm |
George G Member Since: 02 Feb 2015 Location: Derbyshire Posts: 21 |
You will need to remove the tow bar brackets to fit the weld on ARB brackets as they sit in roughly the same position.
17th Oct 2015 10:18pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I can send you a file with info how North offroad connects their cage to the chassis. Send me a pm with your email adress.
Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
17th Oct 2015 11:29pm |
http://www.extreme4x4.co.uk/acatalog/DEF_9...CKETS.html
thanks everyone , so these brackets are for the tow bar and anto roll bar , so if i out them in the same place as my tow bar brackets , i can`t be far out . will check with roll bar first , cheers ady |
18th Oct 2015 11:34am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Just a thought, if you do any green laning or off roading, I'd be inclined to leave the anti-roll bars off.
I took them off my TD5 HT and the ride was so much better and the articulation is great. It made little to no difference to the on road behaviour but miles better once you leave the tarmac. Just my 2c cheers simon |
18th Oct 2015 1:39pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
Xeng do a roll bar which can be disconnected.
18th Oct 2015 1:57pm |
cheers everyone , i`ll have a play n see what i think , i can fit the front easily enough , so may get one to try , if it don`t feel any different , i`ll not worry about the rear , ady
19th Oct 2015 5:24pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2102 |
Didn't want to start a new thread as this is really 'tenuously' related....
I'm having a bit of a runaround trying to source new rear ARB bushes for my std 90 XS. The rear ARB on my truck is 19mm diameter. I've ordered rear ARB bushes from two suppliers and they've both sent me front bushes. Well let me accurately present the facts. I actually ordered rear ARB bushes but those sent were for a 25mm ish ARB and they have a larger overall dimension. I checked them against the front and guess what - a perfect fit. As its a quick job I've now fitted them (to the front!) so no real lives lost - although I've got a spare set. I'm just perplexed. For both suppliers to send me the same thing (25mm) I'm wondering if I have a non standard rear ARB??? Any pointers/guidance. Please don't ask why I ordered two sets - it's a long story! I just want the right bushes........ Cheers, Will |
19th Oct 2015 6:31pm |
