Home > Technical > Wipers not returning to the normal park position
roel
I have a small issue with my front windscreen wipers. They stop directely when I switch them off. What I find strange that it doesn't happen in the intermittent setting.
What can this be? Roel
2003 90 Td5 (2009-now)
Post #464206 17th Oct 2015 9:55pm
StephenO
Wiper park switch, cheap fix 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #464208 17th Oct 2015 10:03pm
roel
I was thinking about that but why does it work in the intermittent setting? Roel
Post #464220 17th Oct 2015 11:26pm
roel
No other reaction? So If it is the park switch why does it work in the intermittent setting? I am not convinced yet. Roel
Post #465531 22nd Oct 2015 3:29pm
VeeTee
Netherlands
Hi Roel, most probably it is indeed the park switch, see this topic here. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #465540 22nd Oct 2015 4:03pm
Johnikgriff
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Ye mine did that. Worked on intermittent but didn't on normal. I swapped the relay (twice) first. But it was the park switch. Not to bad a fix and cheap.
Post #465543 22nd Oct 2015 4:09pm
This.
A common problem from early Ninety's and will be around forever!
Post #465578 22nd Oct 2015 6:10pm
It works on intermittent because the intermittent timer's pulse just happens to be the right duration to run one full wipe. Mine was exactly the same.
Post #465581 22nd Oct 2015 6:14pm
Cold_n_Wet
Norway
it wasnt on mine, I changed the switch, but it was the same, in heavy rain parks correctly, but light rain it doesnt so I have to change the motor and drive Sad "Rafiki" 2007 110 STW - Rolling rebuild.
Post #465627 22nd Oct 2015 8:04pm
roel
Thanks guys, I will change it and see. Thumbs Up Roel
Post #466127 24th Oct 2015 1:59pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I just had this problem of wipers stopping instantly when switched off., it started after I changed the motor for other reasons (slow and old)..
The cause was the pin on the switch getting stuck down, this cuts the live feed when the wipers are off so there is no power for them to return to park position.. The pin on the switch was getting stuck down because the plastic housing around the pin was being pinched by hole on the gearbox housing.
Fixed by filing the hole with a few slides of a small wood file, works perfectly Thumbs Up
Post #471342 10th Nov 2015 4:43pm
jst
mine does exactly the same, where is the switch please? MPN anyone? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #471411 10th Nov 2015 8:54pm
