![]() | Home > Technical > Wipers not returning to the normal park position |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Wiper park switch, cheap fix 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
I was thinking about that but why does it work in the intermittent setting? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
No other reaction? So If it is the park switch why does it work in the intermittent setting? I am not convinced yet. Roel
Hi Roel, most probably it is indeed the park switch, see this topic here. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Johnikgriff Member Since: 08 Mar 2014 Location: Chester Posts: 110 ![]() ![]() ![]() |
Ye mine did that. Worked on intermittent but didn't on normal. I swapped the relay (twice) first. But it was the park switch. Not to bad a fix and cheap.
This. A common problem from early Ninety's and will be around forever! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17727 ![]() ![]() ![]() |
It works on intermittent because the intermittent timer's pulse just happens to be the right duration to run one full wipe. Mine was exactly the same.
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 247 ![]() ![]() |
it wasnt on mine, I changed the switch, but it was the same, in heavy rain parks correctly, but light rain it doesnt so I have to change the motor and drive
Thanks guys, I will change it and see.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
I just had this problem of wipers stopping instantly when switched off., it started after I changed the motor for other reasons (slow and old)..
The cause was the pin on the switch getting stuck down, this cuts the live feed when the wipers are off so there is no power for them to return to park position.. The pin on the switch was getting stuck down because the plastic housing around the pin was being pinched by hole on the gearbox housing. Fixed by filing the hole with a few slides of a small wood file, works perfectly ![]() ![]() Click image to enlarge |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8222 ![]() ![]() ![]() |
mine does exactly the same, where is the switch please? MPN anyone? Cheers
