![]() | Home > Maintenance & Modifications > Fitted my dash cam |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
I fitted my dash cam today, a couple of pics.
Switched via ignition feed. ![]() Click image to enlarge ![]() Click image to enlarge |
Qanfud Member Since: 24 Sep 2015 Location: Sliema Posts: 38 ![]() ![]() ![]() |
Seems to be a job well done. Congrats. Could you elaborate about the wiring please? Thanks
SonikUK Member Since: 02 Oct 2015 Location: Crayford Posts: 11 ![]() ![]() |
Nice job, got the same camera in another car very pleased with it.
Likewise like to hear about the wiring too. |
I have installed a 5v usb charger in the roof lining.
One of these. ![]() Click image to enlarge Taken a negative off the interior light. I ran a new cable to the fuse box down the A pillar. took the aux fuse out and install an Add circuit fuse holder. One of these. ![]() Ignition on Camera on. I hope this helps. ![]() |
I think i will leave it in the car. I can't see the thieves looking out for a 80 quid Camera.
Most of the time it either on my drive away from the road or in my yard at work. |
Interesting. Thanks. Will have to read it a million times till I understand. I wish to have something just permanently circuited. Will get there in time!
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
What make of camera is that ?
Very neat fit. |
Hi
I bought it from Amazon. It's an E-PRANCE® Mini 0805 HD 1296P ![]() |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
I have a nextbase with the hardwire kit, piggy back fuse hold into fuse box on drivers side , wire up the A pillar , under headlining to camera behind rear view mirror , 10 min job and on with ignition
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 ![]() ![]() ![]() |
But it's not on your dash.
![]() Very neat install. Could it be an option to have it recording 24/7. Just for the chance to catch any unwanted types having a snoop. |
Same camera and similar location to mine. I simply took the +live feed for a 5v adapter off the interior light circuit then ran the cable from under the lamp to the camera. The flashing LED can be a distraction at night but is easily solved by covering it with a bit of black insulating tape. Steve.
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 ![]() ![]() ![]() |
No but it does have a motion detection option, it'll record anything that moves. But you'd never know if someone has snooped on your car because you can't watch all the footage back to check. |
Albion Member Since: 08 Dec 2014 Location: Oxfordshire Posts: 141 ![]() ![]() ![]() |
great camera, have one myself. however, regarding the location, I ended up moving mine as being in the centre, where I originally had it, was the exact position neither of the wipers managed to get to, hence the vision of the camera over time is significantly reduced by dirt, rain etc.
I ended up moving it to the centre of the passenger screen, at the apex of the wiper swipe. |
