![]() | Home > Wheels & Tyres > 255's at full articulation |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
that is tight, i presume front is OK? My 109 thread
my youtube channel |
RCMike Member Since: 30 Apr 2015 Location: North Wiltshire Posts: 70 ![]() ![]() |
Yep, the front is OK. Even without an ARB at the front, it doesn't articulate as much as the rear. I've not extended the front bump stops as the axle doesn't reach them and there is a lot more room anyway. Also no trimming required at the front.
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 794 ![]() ![]() ![]() |
Have recently fitted the same set up to my 05 110, mine just clip the inside edges of the front arches as well on full bump/full lock. I need to trim a touch more out of the back of rear arches too I think although I don't think I'll need to trim quite as much as you have- mine somehow seem to 'tuck in' more?
Fitted 255/85/16s to a friend's truck earlier this year on boosts. His fouled the rear spring seats on near full bump at the back-so fitted spacers Chris |
Perhaps mine need's to loosen up a bit at the front.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
I had to trim the inward-facing lip off the front lower corner of each rear flare on my 110. I did the rear lower corners too. My 255s are on Blindos with a 14mm positive offset, and I haven't had any other contact issues.
I am however not optimistic about compatibility with tyre chains - I think that any attempt to use them would rip the flares off the vehicle and enlarge the arches is a rather raggedy manner! ![]() |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
I have 255's on Freestyles (same offset as Boosts I think) and they are fine with standard suspension on my TD5 HT. No rubbing anywhere. ARBs have been removed.
^^^agree that chains would be a very tight/interference fit... ![]() cheers simon |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1636 ![]() ![]() |
i think a lot depends on what wheels you use
the recommended size is 8 inch for best results boosts are 7" ? i used to use this size a few years ago and have gone back it to last year on a 2 inch lift without any issues |
Almost forgot to post a pic of the front's under full compression with the 255's (well almost - the axle was about 5 to 10mm from the bump stop). Looks very tight but still room without rubbing.
