![]() | Home > Td5 > Td5........lack of boost |
alwoodley72 Member Since: 14 Mar 2010 Location: salisbury, wilts Posts: 727 ![]() ![]() ![]() |
Mine had a blocked cat too, night and day after fitting cat removal pipe....( that was after replacing fuel pump, mag, egr removal , loom, etc etc!!..)
They are all now' of an age'.. Cheers. Alex 98 300 tdi 90 project 94 Range Rover vogue 4.2 lse 79 911 sc 08 130 double cab utility |
I know yours is a TD5 but you'll get the idea if you think it's the cause and you'll have no mither MOT time as the TD5 Cat is in such an obvious location.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Treat every day as if it is your last....one day you will be right!! |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
^^ I wonder if that would work for the dpf on my 2.2
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Intercooler hoses are normally soft. I'd go gen LR myself, I think the funky coloured ones are a waste of money
It's a little long from the joints to get a drill into a Td5 cat
Length of rod may do it. My 'cat' is fitted in the same place as a TD5 one, but I think you may not have a join in the same place as a Puma exhaust as depicted. You could consider fitting a join after the hanger perhaps for 'cat' access?
![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 26th May 2015 7:52am. Edited 1 time in total |
JimboD3 Member Since: 09 Apr 2013 Location: Ware, Herts Posts: 55 ![]() ![]() ![]() |
What's the reasoning behind 'removing' the cat - does it clog up with something over time (I appreciate my 110 is approaching 11yrs old, but the mileage is low - approx 28k) ?
Jim Td5 110 HD Hardtop.......not quite standard ![]() |
Removing the 'cat' will allow the engine to breathe easier and the turbo to spool up quicker. There's loads of information on the forum if you look under 'decat.' Having 'had a few blocked' Fatboy Slim may be able to elaborate. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
The length behind the td5 cat is not the mayor problem it's the 2 bend that prevent you from drilling it out.. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
They block. Especially on low milers. Quick easy diagnostic test: take it off and take it for a blast. No need to buy/drill/hack anything off. Noisy? Yes. Detrimental? No, not for a quick jolly out to see if it's any better.
Are there any other symptoms to be had with a blocked cat ?...........only recently I've noticed a 'tinkling' noise when the engine is under load - I initially thought it was the pads rattling again in the X-brake, but it's not.......do cats make a funny noise when they get blocked and/or start to break down internally ?
I've also been trawling the t'interweb for possible replacement exhaust systems/cat replacements - but don't you need a cat for the MoT now ? - some sites seem to advertise a 'C-Cat' rather than a 'D-Cat' pipe, which presumably looks like a cat but with nothing inside it ! Has anyone had experiences with C-Cat replacement pipes - and do I actually need a cat (2003 Td5) Thanks, Jim Td5 110 HD Hardtop.......not quite standard ![]() |
markp85 Member Since: 14 Oct 2014 Location: wrexham Posts: 1 ![]() |
I had the same problem a few months ago...
it was the map sensor on the inlet manifold a few inches away from the egr valve/blank ... needed to be replaced... 2001 td5 defender |
