Home > Puma (Tdci) > Code reader recommendation
Stacey007
Hello
Following from my light on the dashboard this morning Sad
What code readers do people recommend, where does it plug in and is there a list of codes and what they mean?
I don't want to make things worse but a quick Google suggest my Engine management light could be anything... and the car drove completely fine when on. So it could be worth me buying one for now and future.
Thanks
Post #463445 15th Oct 2015 11:47am
K9F
It is advisable as stated in the other thread you're running.....
Scangauge or Ultragauge....pound for pound and what you will need it to do they are the best money. Stacks of information on both if you are able to do a search?
http://www.defender2.net/forum/topic37795....ound+pound If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463466 15th Oct 2015 12:29pm
Stacey007
Thank you
Sorry more in panic mode as worried what's wrong so not used the search..
Thanks
Post #463469 15th Oct 2015 12:32pm
K9F
I will wager that it is an EGR related code that will disappear either today or tomorrow after you've driven it properly 5 or 6 times. I have had a Scangauge II for several years and it has done everything I need it to do. Basically read and reset codes. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463473 15th Oct 2015 12:39pm
Stacey007
Thanks ^
Is this the job Smile
http://www.ukobd.co.uk/vmchk/Hand-held-Tools/ScanGauge2.html
I do worry when lights are on the dash... If I get this and plug it in it will then let me know the error code that I can look up?
Then reset it?
I assume if something is major it will come back on though?
Thanks again
Post #463475 15th Oct 2015 12:56pm
K9F
^^Ideal. It will tick all your boxes and all the codes are available online. If not once you've got the reader drop me a 'pm' with your e-mail and I'll send them all to you willingly!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #463513 15th Oct 2015 4:20pm
JOE_130
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Java Black
Hi all,
Sorry to resurrect an old thread but thought it was better than starting a new one on code readers - does anyone have any recommendations for an OBD tool that will carry out a static/forced regeneration of the DPF on a 2.2 puma?
Autel tools can do DPF service functions on everything but a defender annoyingly. Anticipating the "just drive it like you stole it for ten minutes" that's not always possible in some parts of the world a Defender can carry you to Sad If there'd have been an options box called "DPF delete" on the order form I would've ticked, underlined, and circled it.
Joe
Post #514217 14th Mar 2016 3:54pm
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
i tried one which needed a programme on computer but not vey good so i purchased a basic one off eBay at £16.79 and its performed great.
FOR LANDROVER FAULT CODE READER ENGINE SCAN DIAGNOSTIC RESET EOBD OBD2 CAN BUS
( eBay Item No. 251982654590 )
Post #514222 14th Mar 2016 4:17pm
That's the sort of thing I used to have! Sold it though since having the ATRIC device from Alive which does the same thing.
Post #514256 14th Mar 2016 6:11pm
JOE_130
Thanks for the replies.
Does the Alive Atric (I'm assuming that's the calibration flash tool they supply?) have the ability to force a dpf regen then or is it just a code reader? I'll certainly be after a re-map from somewhere as soon as its out of warranty.
Thanks Smile
Post #514469 15th Mar 2016 9:48am
That'd be a question best answered by Gary @ Alive himself.
I'll notify him of your question. Thumbs Up
Post #514533 15th Mar 2016 2:03pm
JOE_130
Thanks Very Happy
Post #514542 15th Mar 2016 2:24pm
Forced regen was discussed here, but no firm conclusion as to whether it's actually possible:
http://www.defender2.net/forum/topic43234....p;start=15
Post #514558 15th Mar 2016 3:29pm
