![]() | Home > Puma (Tdci) > Code reader recommendation |
It is advisable as stated in the other thread you're running.....
Scangauge or Ultragauge....pound for pound and what you will need it to do they are the best money. Stacks of information on both if you are able to do a search? http://www.defender2.net/forum/topic37795....ound+pound If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Thank you
Sorry more in panic mode as worried what's wrong so not used the search.. Thanks |
![]() I will wager that it is an EGR related code that will disappear either today or tomorrow after you've driven it properly 5 or 6 times. I have had a Scangauge II for several years and it has done everything I need it to do. Basically read and reset codes. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks ^
Is this the job ![]() http://www.ukobd.co.uk/vmchk/Hand-held-Tools/ScanGauge2.html I do worry when lights are on the dash... If I get this and plug it in it will then let me know the error code that I can look up? Then reset it? I assume if something is major it will come back on though? Thanks again |
^^Ideal. It will tick all your boxes and all the codes are available online. If not once you've got the reader drop me a 'pm' with your e-mail and I'll send them all to you willingly!
![]() Treat every day as if it is your last....one day you will be right!! |
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 105 ![]() ![]() ![]() |
Hi all,
Sorry to resurrect an old thread but thought it was better than starting a new one on code readers - does anyone have any recommendations for an OBD tool that will carry out a static/forced regeneration of the DPF on a 2.2 puma? Autel tools can do DPF service functions on everything but a defender annoyingly. Anticipating the "just drive it like you stole it for ten minutes" that's not always possible in some parts of the world a Defender can carry you to ![]() Cheers Joe |
Albert s Member Since: 20 Oct 2013 Location: Nth lincs Posts: 41 ![]() ![]() ![]() |
i tried one which needed a programme on computer but not vey good so i purchased a basic one off eBay at £16.79 and its performed great.
FOR LANDROVER FAULT CODE READER ENGINE SCAN DIAGNOSTIC RESET EOBD OBD2 CAN BUS ( eBay Item No. 251982654590 ) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20722 ![]() ![]() |
That's the sort of thing I used to have! Sold it though since having the ATRIC device from Alive which does the same thing.
Thanks for the replies.
Does the Alive Atric (I'm assuming that's the calibration flash tool they supply?) have the ability to force a dpf regen then or is it just a code reader? I'll certainly be after a re-map from somewhere as soon as its out of warranty. Thanks ![]() |
That'd be a question best answered by Gary @ Alive himself.
I'll notify him of your question. ![]() |
Thanks
Forced regen was discussed here, but no firm conclusion as to whether it's actually possible:
http://www.defender2.net/forum/topic43234....p;start=15 |
