Home > Td5 > Bulkhead vents adjustment/seals
excossack
Is there any adjustment on the bulkhead vents to get the vent to closer properly?
Mine don't appear to close all the way and I get a draft (certainly on the drivers side) that I can feel when driving.
In summer its OK, but in winter it can get a bit annoying.
Are there improved seals available? Mine are the foam type and attached to the vent flap 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #462955 13th Oct 2015 5:53pm
JWL
I have a similar problem but with mine you can physically see that the vents don't touch the same all around the opening. This I've put down to my not so nimble as he thinks youngest son who insisted in accessing the roofrack from the bonnet and I think he used the then open vent to gain an extra foothold which in turn has bent the hinge where it's attached to the bulkhead.
I just haven't got round to encouraging it back into the original pose
Post #462986 13th Oct 2015 7:43pm
Triggerfinger
Just knock the pins out then twist the flap towards the bonnet,
Im sure its 8mm nut & bolt (royal pain in the ass if unless you've got woman's hands)
just slacken it off a touch & re-adjust to suit.
or the fix it the lazy way & put another seal on top of the original one and ram it home lol Thumbs Up
Post #463025 13th Oct 2015 9:19pm
CarMan
I've got exactly the same problem as excossack, though mine don't seem to open fully or close fully. Anyway, guess I'll knock the pins out and have a look see . . . . . . . .
Post #463110 14th Oct 2015 7:35am
excossack
Are these the external pins (the two above each flap?) 1999 Defender TD5 110
Regards
John M0VAZ
Post #463113 14th Oct 2015 8:09am
Triggerfinger
That's the ones, prob just need freeing up form lack of use Wink
Post #463188 14th Oct 2015 11:57am
excossack
I have replaced 3 of the four with stainless. The one remaining is on the drivers flap; so I guess its possible this one could be stopping the flap closing properly. 1999 Defender TD5 110
Regards
John M0VAZ
Post #463196 14th Oct 2015 12:38pm
alexatnd
Where did you get the stainless versions from?
Had to use lots of WD40 to shift the ones on Effie but still doesn't quite shut completely Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #463774 16th Oct 2015 12:54pm
excossack
Ebay for the bolts. 1999 Defender TD5 110
Regards
John M0VAZ
Post #463778 16th Oct 2015 12:58pm
mk1collector
4x4 overlander (site sponsor) also sell the pins. Ray
My build thread
Post #463783 16th Oct 2015 1:03pm
jimbob7
I used lots of penetrating oil and brute force to remove my sized vent pins,I replaced them with stainless jobbies and plenty of grease. They are slick as anything now,happy days during the summer. Pov.spec,ftw. 2006, 110,TD5.
Post #463799 16th Oct 2015 2:18pm
