Home > Td5 > Bulkhead vents adjustment/seals |
I have a similar problem but with mine you can physically see that the vents don't touch the same all around the opening. This I've put down to my not so nimble as he thinks youngest son who insisted in accessing the roofrack from the bonnet and I think he used the then open vent to gain an extra foothold which in turn has bent the hinge where it's attached to the bulkhead.
I just haven't got round to encouraging it back into the original pose |
13th Oct 2015 7:43pm |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 |
Just knock the pins out then twist the flap towards the bonnet,
Im sure its 8mm nut & bolt (royal pain in the ass if unless you've got woman's hands) just slacken it off a touch & re-adjust to suit. or the fix it the lazy way & put another seal on top of the original one and ram it home lol |
13th Oct 2015 9:19pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1833 |
I've got exactly the same problem as excossack, though mine don't seem to open fully or close fully. Anyway, guess I'll knock the pins out and have a look see . . . . . . . .
14th Oct 2015 7:35am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5823 |
Are these the external pins (the two above each flap?) 1999 Defender TD5 110
14th Oct 2015 8:09am |
That's the ones, prob just need freeing up form lack of use
14th Oct 2015 11:57am |
I have replaced 3 of the four with stainless. The one remaining is on the drivers flap; so I guess its possible this one could be stopping the flap closing properly. 1999 Defender TD5 110
14th Oct 2015 12:38pm |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 263 |
Where did you get the stainless versions from?
Had to use lots of WD40 to shift the ones on Effie but still doesn't quite shut completely Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
16th Oct 2015 12:54pm |
Ebay for the bolts. 1999 Defender TD5 110
16th Oct 2015 12:58pm |
4x4 overlander (site sponsor) also sell the pins. Ray
16th Oct 2015 1:03pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I used lots of penetrating oil and brute force to remove my sized vent pins,I replaced them with stainless jobbies and plenty of grease. They are slick as anything now,happy days during the summer. Pov.spec,ftw. 2006, 110,TD5.
16th Oct 2015 2:18pm |
