Home > Maintenance & Modifications > Rear corner protectors - pictures.
Page 2 of 3 <123>
gilarion
taffrican, I like them very arty and different and I have not seen that style before, maybe not to every ones taste but is not moding meant to be a little bit unlike the others, not the same. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #462771 13th Oct 2015 1:09am
MartinK
+1 for Safari Equipe
Worth thinking what you want them for. Mine have saved me from a nasty crunch already when I reversed into a bollard. Bent the bollard...no damage to the Bumperette.
Great for standing-on when cleaning the roof or accessing a load on the roofrack.
However also bear in mind if you want to fit another accessory.
I fitted a Nakatenanga swing-away wheel carrier:
As you see the wheel carrier used some of the existing holes which the Bumperette also uses. So I had to modify the Bumperette:
All great now.
The Safary Equipe Bumperettes are in great shape after 4 years.... no corrosion and they do the job very well Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #462783 13th Oct 2015 7:50am
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
I had a pair of these on for two weeks recently before I added a Nakatenanga swing-away wheel carrier after the PB show.
£85-00 excluding postage and they are yours Smile
Steve
Post #462786 13th Oct 2015 8:32am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
nitram17 wrote:
Theater wrote:
Cor4x4
http://www.davidecorsetti.com/prodotti.php...id_cat2=19
Im sorry but they lare a bit overdesigned and thin for my taste..how much?
€ 410,00 ( left & right )
Product # : COR 243
http://www.davidecorsetti.com/prodotti.php..._cat3=108;
Available also for the swingaway wheel carrier with the right side short:
€ 205,00 Rigth
Product # :COR 45
For these Rear Corner Protectors you need also le "Cover":
€ 130,00 for kit
Product # : COR 252
http://www.davidecorsetti.com/prodotti.php..._cat3=112;
or :
Full -Kit
€ 340,00 for kit
Product # : COR 131
http://www.davidecorsetti.com/prodotti.php...id_cat2=19 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #462842 13th Oct 2015 11:15am
mikeh501
I have these on mine. From border motorsport. The good thing is that it also replaces the mudflap bracket which always rusts out and it moves the mudflap upwards by 1" which stops it being ripped off by the wheel off road.
[/img]
Post #462846 13th Oct 2015 11:29am
JOW240725
Pm sent HairySteve.
Post #462863 13th Oct 2015 12:26pm
YOLO110
Australia
Does anyone know if you can fit the Mantec rear wheel carrier with the 'TerraFirma' rear corner protectors? YOLO... You Only Live Once...
Post #463097 14th Oct 2015 12:39am
JohnD2
Australia 2015 Defender 110 Puma 2.2 SW Keswick Green
I have Equipe4x4 fitted to 110. Can't fault the quality or fit. Maybe another option to consider YOLO? The Mantec carrier will fit with respect to bolting onto cross member without any modification to bumperette. Not sure though if full door opening will cause the Mantec frame to foul on the back of the bumperette though.
Post #463100 14th Oct 2015 5:45am
YOLO110
Australia
Another Keswick Green Defender in NSW! GREAT! Thumbs Up
Many thanks for the post. I already have TerraFirma bumperetts fitted so don't really want to change them! But I would like to fit the Mantec wheel carrier as the HD wheels are rather heavy! Shocked
Where in NSW RU mate? I am in Wollongong? YOLO... You Only Live Once...
Post #463101 14th Oct 2015 6:22am
JohnD2
Hi Pete. From Newcastle, so same poor cousin just on the north side.
Sorry for going off topic, especially without posting in the welcome section first. Admiration for your passion for Keswick is too much to resist. Grasmere green with matching wolfs and a white roof though - gwaaaaarh.
Post #463157 14th Oct 2015 10:31am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Has anybody fitted the Equipe corner protectors to a 90? I have just received a pair from Trek Overland and upon offering them up to the back of my 90 it looks like they are going to foul the mudflap brackets.
Post #465916 23rd Oct 2015 7:20pm
Screbble
Less than £100 on the bay of E.
Been fitted for some time now. Really strong, well made and I think they look 'nice.' Wink
Post #466046 24th Oct 2015 8:45am
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
I have some made by an English company called Venuture.
Only niggle I have is that as the rear cross member on the new puma tapers in at the ends, it makes the bit that wraps round the side not quite parallel with the wing. However, you could put a spacer under the outer side to make it parallel.
Post #466697 26th Oct 2015 3:22pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
I also have these, very we'll made and very strong, they do a wheel carrier version too.
Only issue I've had with them, and it's only because i put them on my 300, is that the exhaust vibrates against it sometimes, an issue that isn't there with later models with exhaust that are lower and point to the rear.
Post #466725 26th Oct 2015 5:29pm
johnnyha
1996 Defender 90 300 Tdi CSW Epsom Green
resurrecting an old thread - anyone aware of a set for the 130?
Post #966161 28th Sep 2022 12:49pm
Page 2 of 3 <123>
