Home > In Car Electronics > terminals on a britpart 9000c winch |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Do you have any images of the motor? Usually there are three studs: F1, F2 and an earth. The earth is often on the underside of the motor. Tthe F1 and F2 are the winch-in and winch-out configurations.
Are you wiring it using the original solenoid box or albright solenoid? |
11th Oct 2015 1:00pm |
Crasher Member Since: 17 May 2014 Location: Douglas Posts: 6 |
Click image to enlarge Hi Mike I have attached a couple of pics This is the original winch nothing changed. As you can see from the picture with the top view the positive in on the left and negative on the right. The second picture shows the cable from the switch to the terminals that cross over, hence why I have connected the cables as I have, Red Right and black left. When I first went to connect the negative to the battery I got a load of big sparks, which made me wonder if I have the cables connected properly. Didn't want to change anything over until I was sure which way round they should be. Or is it that I should have connected the negative first and then the positive. THe winch cables are not connected to the battery now. Thanks for your time for such a simple question Click image to enlarge Click image to enlarge |
11th Oct 2015 5:14pm |
