Home > Puma (Tdci) > My rear lights are coming on by themselves |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
do you mean the brake lights are staying on 2.4 90 XS
24th Nov 2010 2:34pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
If you've got a trailer socket fitted, check for shorts in the back. (Stray wire strands)
24th Nov 2010 2:37pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
If it's brake lights (i would have though it is, if the 3rd one is lighting up as well) then more likely a badly adjusted brake light switch, or one of the spade terminals has been knocked off and is touching an earth point (without looking at the wiring diagram, i don't know if the lights themselves are powered and then ground to earth via the switch, or the power stops at the switch until you press the pedal)
24th Nov 2010 2:39pm |
Terrier Member Since: 24 Nov 2010 Location: Wales Posts: 4 |
Many thanks for your replies, I think that it is the brake lights but it is odd to me that the high level brake light comes on with the other two, and sometimes it does not.
I am not much good on electrics but will start to check trailer socket etc for anything obvious. I have just been told by someone who services defenders that there has been a bad batch of bulbs, and by changing them has cured some faults. |
24th Nov 2010 3:29pm |
24th Nov 2010 3:47pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
just take it back to the dealer (or try a different one) and tell them to sort it. its under warranty after all.
24th Nov 2010 8:24pm |
