Home > My Defender > Corris 110....
Page 3 of 48 <123 4 ... 464748>
mk1collector
That looks great Thumbs Up did you just cut up the old dash centre for the switch holes? Ray
My build thread
Post #461612 8th Oct 2015 5:22pm
mcma1
Yup,
Just cut the sections out, and then carfully sanded them nicely, adding some rads etc. I wanted to keep the LR switches so very happy.
Post #461617 8th Oct 2015 5:35pm
mk1collector
Excellent job, I've been thinking of doing something on a similar line for a while but im waiting for a centre piece that someone has already cut the top off for the double din mod. Ray
My build thread
Post #461627 8th Oct 2015 6:24pm
Stiff1
That looks amazing. What do you mean by added some rads?
Also what did you cut it with?
Are they all from the top line of buttons?
Thanks
Post #461632 8th Oct 2015 6:37pm
mcma1
Originally I was just going to add 3 switches for the spots, but when I decided on the double din today I thought I would give it a go..I cut the three from the bottom and 3 from the top out with a 4" grinder but oversized. Then I used a belt sander to square and size them up. You then need to tidy up the back and make the thickness of the over hang pretty even. Then I rounded the corners and top edges by hand (added rads). They are just press fitted into the holes so no need for glue etc.A final clean and light spray of satin black and they look like finished parts.
Post #461637 8th Oct 2015 6:54pm
Venomator
mcma1 wrote:
Fitted the mantec wheel carrier, very easy to do, just one hole to drill out as we all know... the thing i dont like is pressing metal on metal do i added some pads and rubber washers behind the brackets etc. Took about 1.5 hrs to do, feels much better opening the door now with the 18" wheel on it.
Great job on the Mantec matey... Bow down
Your skills and attention to detail on this truck are awesome, love the work you are doing sir... Thumbs Up
I am always envious of those that are capable of doing such great things with their P&J... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #461652 8th Oct 2015 7:14pm
mcma1
Cheers buddy,
My last defender broke my heart, did so much to it but deep down I knew I should have started with a 110... Anyway onwards and upwards.
Post #461660 8th Oct 2015 7:26pm
mcma1
Should be able to see ok when this all goes on!!
4 TS4000's Black for the rack
Pair of Evo 2's Black
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #461906 9th Oct 2015 6:47pm
mcma1
Some more work this afternoon,
Rear stainless strip.
Fitted the Evo 2's and Wipac side and indicators. Will tackle the spots next.
2014 Corris 110 SW
LS3 V8 build...
Post #462123 10th Oct 2015 6:30pm
mcma1
TS 4000's mounted, wiring for another day....
2014 Corris 110 SW
LS3 V8 build...
Post #462284 11th Oct 2015 2:16pm
mcma1
Plan to get the double din and rear camera fitted over the weekend so made a start on the wiring. This is the switch arrangement I have gone for in the cubby. Bottom row is just rear fog, front rack lights, and then using a discovery top for either the rear camera or maybe a rear work light, not sure yet. Swapped the discovery switch head onto a heated seat latch switch and then just drilled a 3mm hole for the LED light when active.
Quite a load of wiring to extend but the carpets are pretty forgiving for hiding it so I just made up a loom and brought it through the gear sticks, can't be seen at all.
All connected, lighting up and doing what they are meant to do... Much more room in the dash now as well to help with the HU fitting Smile
2014 Corris 110 SW
LS3 V8 build...
Post #463280 14th Oct 2015 5:44pm
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
I like this alot! Very nice Thumbs Up
Post #463288 14th Oct 2015 5:57pm
mcma1
Thanks,
Just need to trim out the inside off the cubby box now to protect the switches and job done...looks good in the dark. Smile Andy
2014 Corris 110 SW
LS3 V8 build...
Post #463292 14th Oct 2015 6:02pm
JOW240725
Looks great, very impressed with your work! Keep up the thread really enjoying it.
Post #463319 14th Oct 2015 7:11pm
mk1collector
That looks fantastic Thumbs Up don't know if it's something you'd want as you've sorted the switch for the rear camera but I came across this from aus while looking for switches.
http://www.expeditioncentre.com.au/online-...variations
There's a rear camera switch, rear work light switch, winch, and a few others. I realise the switch itself will probably be the same as you've used but the switch caps look very factory. Cool
Ray Ray
My build thread
Post #463333 14th Oct 2015 7:57pm
