Home > Maintenance & Modifications > picture of wipac rear led lights anyone? straight swap? |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3758 |
Hello
Are these a direct swap for originals? plug and play anyone have a picture fitted please, looks to be two kits clear or coloured. http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...566f1b31ed http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...566f1b30cf Thanks |
7th Oct 2015 8:17pm |
midlife Member Since: 15 Apr 2015 Location: Cork Posts: 122 |
I have the Wipac coloured. Straight swop plug and play on a Puma. Just fit the relay supplied under steering wheel
7th Oct 2015 8:35pm |
Do you have a picture please.
Are you happy with them? Thanks |
7th Oct 2015 8:38pm |
Too dark for photo. But very happy with them. Much brighter especially side/position lights
7th Oct 2015 8:42pm |
I think there is a picture of them in my defender section
7th Oct 2015 8:43pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
There you go, I went for traditional coloured on the rear, but clear is an option and just look like the front lenses (second photograph)... Click image to enlarge Click image to enlarge Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
7th Oct 2015 9:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Me too. ^^^^ Photos in my 'gallery' somewhere I think.
7th Oct 2015 10:51pm |
Wipac...
Click image to enlarge Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Oct 2015 11:21pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Slightly when did they change the rear badge back to DEFENDER without the puma swoosh...i noticed it on ours and the one in here has the same Mike
8th Oct 2015 7:10am |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
I thought I've read something about problems with the trailer lights with the Wipac relay or has that been solved in time? Getting fed up at the moment as it seems no matter how many times they get replaced under warranty, they always turn into fishbowls over time again... |
8th Oct 2015 7:27am |
A couple of people have mentioned this but I found no issues whatsoever with the Wipac relay supplied. Not sure if the Wipac relay may have been upgraded but it came with the kit and works a treat with the trailer light being adjustable to the point it flashes only once, exactly the same as having OEM lights fitted. What is a little misleading perhaps is the fact they claim "When installing LED indicators/turn signals you will have to use the compatible LED relay supplied to correct the ‘fast flash’ characteristic when retro fitting LED indicator/turn signals." Whilst true what they forget to mention is that the adjuster on the relay itself does not actually change the rate of flash. It actually adjusts the trigger point of your dash trailer light illuminating. It should be adjusted so the trailer light illuminates once when the indicators are initiated without a trailer fitted. Hope this makes sense. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Oct 2015 8:36am |
Thanks all
Now the question, do I go clear all round... or coloured at the back (I like the clear front) My Defender is Black. P.S I like that wheel carrier also.....aarrgghh tooo many bits tooo little time |
8th Oct 2015 10:59am |
Personal choice really. A little work is required if you decide to go the whole hog, on the Wipac fog and reverse lights as they are not quite plug and play. They need to be spliced and the fog was not available in clear, Bearmach do a clear fog but the lens pattern differs significantly from Wipac.(It may well be now perhaps?)
Wheel carrier manufacturer can be seen on plate in above photo. Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Oct 2015 12:24pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
I went for the Wipac clear uncoloured lamps for mine to keep with the black and silver theme, (I want to get the roof done in black next.)
No trouble fitting them, all just plug and play Desperately needs a wash though Click image to enlarge Click image to enlarge |
8th Oct 2015 2:20pm |
