Home > Maintenance & Modifications > picture of wipac rear led lights anyone? straight swap?
Stacey007
Hello
Are these a direct swap for originals? plug and play
anyone have a picture fitted please, looks to be two kits clear or coloured.
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...566f1b31ed
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...566f1b30cf
Thanks
Post #461400 7th Oct 2015 8:17pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
I have the Wipac coloured. Straight swop plug and play on a Puma. Just fit the relay supplied under steering wheel
Post #461407 7th Oct 2015 8:35pm
Stacey007
Do you have a picture please.
Are you happy with them?
Thanks
Post #461408 7th Oct 2015 8:38pm
midlife
Too dark for photo. But very happy with them. Much brighter especially side/position lights
Post #461410 7th Oct 2015 8:42pm
midlife
I think there is a picture of them in my defender section
Post #461412 7th Oct 2015 8:43pm
Venomator
Re: picture of wipac rear led lights anyone? straight swap?
Stacey007 wrote:
Hello
Thanks
There you go, I went for traditional coloured on the rear, but clear is an option and just look like the front lenses (second photograph)... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #461429 7th Oct 2015 9:55pm
Screbble
Hi Stacey007,
I bought and fitted the RDX LED set from Bolt On Bits (also on eBay). They are very similar to the WIPAC, and both get good reviews, however I can only comment on the former.
Plug and play without a doubt. A very quick, satisfying job indeed. A doddle........ Thumbs Up
I went for coloured rear and clear front to replace like for like on my XS.
They make a tremendous difference.
Go for it. You won't be disappointed. Very Happy
Post #461436 7th Oct 2015 10:33pm
Me too. ^^^^ Photos in my 'gallery' somewhere I think.
Post #461437 7th Oct 2015 10:51pm
K9F
Wipac...
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #461444 7th Oct 2015 11:21pm
mse
Slightly Off Topic when did they change the rear badge back to DEFENDER without the puma swoosh...i noticed it on ours and the one in here has the same Mike
Post #461477 8th Oct 2015 7:10am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I thought I've read something about problems with the trailer lights with the Wipac relay or has that been solved in time?
Getting fed up at the moment as it seems no matter how many times they get replaced under warranty, they always turn into fishbowls over time again... Confused
Post #461482 8th Oct 2015 7:27am
K9F
A couple of people have mentioned this but I found no issues whatsoever with the Wipac relay supplied. Not sure if the Wipac relay may have been upgraded but it came with the kit and works a treat with the trailer light being adjustable to the point it flashes only once, exactly the same as having OEM lights fitted.
What is a little misleading perhaps is the fact they claim "When installing LED indicators/turn signals you will have to use the compatible LED relay supplied to correct the ‘fast flash’ characteristic when retro fitting LED indicator/turn signals." Whilst true what they forget to mention is that the adjuster on the relay itself does not actually change the rate of flash. It actually adjusts the trigger point of your dash trailer light illuminating. It should be adjusted so the trailer light illuminates once when the indicators are initiated without a trailer fitted. Hope this makes sense. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #461498 8th Oct 2015 8:36am
Stacey007
Thanks all
Now the question, do I go clear all round... or coloured at the back (I like the clear front)
My Defender is Black.
P.S I like that wheel carrier also.....aarrgghh tooo many bits tooo little time
Post #461538 8th Oct 2015 10:59am
K9F
Personal choice really. A little work is required if you decide to go the whole hog, on the Wipac fog and reverse lights as they are not quite plug and play. They need to be spliced and the fog was not available in clear, Bearmach do a clear fog but the lens pattern differs significantly from Wipac.(It may well be now perhaps?)
Wheel carrier manufacturer can be seen on plate in above photo. Thumbs Up
Post #461561 8th Oct 2015 12:24pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I went for the Wipac clear uncoloured lamps for mine to keep with the black and silver theme, (I want to get the roof done in black next.) Cool
No trouble fitting them, all just plug and play Thumbs Up
Desperately needs a wash though Rolling Eyes
Post #461574 8th Oct 2015 2:20pm
