Home > Technical > 1985 D90 not cranking
FLFAMILY
United Kingdom 1985 Defender 90 BMW M52 2.8i Petrol ST Keswick Green
Hi - Trust everyone is having a great weekend. I am in need of some assistance to troubleshoot a problem at hand. I started my Defender (1985, Petrol, 4 Cylinder) this morning, pulled it out of the garage, it ran for a couple of minutes and died out. I saw a tiny bit of smoke and definitely a slight burning smell from the area attached in the picture. This is right behind the fuel tank. Do I have a faulty fuel pump or is it an electrical issue at hand? I don’t think jump starting is going to help, as I picked up the burning smell just as the vehicle died.
Would appreciate any tips that would help isolate the issue so I can order the correct part (Being in the US, parts are not readily available)
Post #460097 3rd Oct 2015 3:02pm
K9F
I am not familiar with a 1985 petrol model. If it won't crank it seems unlikely that the fuel pump is the sole issue unless it has ruptured a fuse elsewhere. Disconnect the battery as a matter of priority. Check the battery once disconnected to see what the terminal voltage is and check the fuses this may too give you a pointer as to where the issue may lie. Ideally you need a decent light source and thoroughly clean down and inspect the area carefully you suspect the smoke to have come from, this may reveal your underlying issue. It sounds like either the insulation may have thrown it's hand in and/or you've had a short circuit somewhere?
*EDIT* That is indeed the fuel pump. I didn't think it was initially. Did a bit of Googling....
Once cleaned if you have access to an insulation tester or an automotive electrician you/he could carry out an insulation check to see if you have a short circuit perhaps on the pump or even remove the pump and dry run it on a fused 12 volt DC supply to check it?
Prices vary considerably.... Shocked
https://www.lrdirect.com/PRC3901-Fuel-Pump...-Line-Fac/
Good luck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #460098 3rd Oct 2015 3:17pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi FLFamily
If your fuel pump has given up the ghost you can replace it using a Facet pump which are produced in the US, i have used these on a Series 3 I used to race and I now have a pair of red tops on my Bowler
http://www.facet-purolator.com
Thumbs Up Thumbs Up 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #460316 4th Oct 2015 12:54pm
FLFAMILY
Many thanks for your response K9F and jomara. I took the battery out and had it tested and it tested fine. Fuses appear to be fine as well. Planning on having it towed to my mechanic this Friday, but will pick up a fuel pump in advance just in case it is the culprit.
jomara - Would you have to know the specific model# that would work on my 85 D90?
Post #460320 4th Oct 2015 1:07pm
K9F
The 'Facet' one is the fourth one down in my link.
Contact them your side of the 'Pond.'
http://www.facet-purolator.com/contactus.php
I suspect it is the Gold-Flo SEP60SV you may need? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #460325 4th Oct 2015 1:26pm
jomara
The info I have on the fuel flow required for standard V8s shows:
3500cc V8 Rover engines
113.65 litres / hour 25 UK Gallons / hour 30 US Gallons / hour running around 4 - 5 PSi
Hope this helps. Thumbs Up 2014 110 2.2TDCi XS Station wagon
Post #460348 4th Oct 2015 3:30pm
