Home > Puma (Tdci) > Wheel spacers |
BH a few threads on them....
Should you perhaps be considering changing your wheels a decent offset will give you the same 'look' without the expense of buying the spacers. http://www.defender2.net/forum/topic16778.html?highlight=spacers http://www.defender2.net/forum/topic36745.html?highlight=spacers http://www.defender2.net/forum/topic35317.html?highlight=spacers They can also create issues.... http://www.defender2.net/forum/topic32739.html?highlight=spacers If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Oct 2015 12:42pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
I have a friend who fitted them and now his has always got dirt up the sides which is enough to put me off. Can't have my Landie with dirt on it.
3rd Oct 2015 5:57pm |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Dirt defenders help with the dirty spray, cited them to my 110 makes a big difference.
http://www.mudstuff.co.uk/dirt-d-fenders.html 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
3rd Oct 2015 6:13pm |
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 |
Now then Boss, have both on my keeper.
Standard Wolf rims with MTR's and spacers in Winter. Overfinch 18inch five spokes with Bridgestone in the Summer. Both have the same offset, IE at the full extent of the wheel arches. Which means a better turning circle after adjusting the lock stops. Handling should be better having a wider track, but it is a Defender not a boy racer. Yes you do get mud / road dirt down the sides, unless you fit rear dirt fenders and the Glynn Lewis extended front mud flap. Fit the GL front outrigger protectors at the same time and save your chassis. But after all the above the motor looks dam good. Cheers West Yorkshire Lofty |
4th Oct 2015 9:01am |
BossHog Member Since: 28 Jun 2013 Location: Fylde Coast Posts: 185 |
Thanks for your responses, don't intend to change the wheels as mentioned, currently on saw tooth's which I actually like.
Couple of good options there reference mud protection, though being honest I have more of a garage queen than a mud buster ! .. I did see arch exstenders on a 90 HT at Peterborough, a good option to keep the wheels within the arch anyone know who sells these? Thanks |
4th Oct 2015 5:16pm |
