Home > Technical > Does a 110 have self leveling rear suspension?
Stacey007
Hello
I have had this on my previous cars and its very handy when towing . Does the 110 have this?
Thanks
Post #459939 2nd Oct 2015 8:14pm
JAY BOY
Wales
Not as standard fella
Post #459940 2nd Oct 2015 8:18pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I dont think any defender has slef leveling suspension, although you could use other options to prevent excessive sag when towing, or heavily loaded.
Air suspension would be the perfect fix. That can be raised to compensate for heavy trailers etc. `air supsension is very expensive though
Air bags can be retrofitted inside the rear springs. They are pumped up with an adapter and are a bit more cost-effective.
Helper springs are another option. This is essentially a spring within the rear spring. Relatively cheap to do, although the down side is that when you arent carrying heavy load, you have a really stiff rear axle..
Post #459941 2nd Oct 2015 8:19pm
Stacey007
Thanks,
Will have to wait and see then although doubt many people add it to the spec?
Post #459942 2nd Oct 2015 8:20pm
shaggydog
They do usually have a Boge unit if that is what you mean?
Looks like this when new
This a few years after
And here is a drawing
Its also usually referred to as an A-frame and as far as I can tell is fitted mainly to 110's to help control body roll when loaded. I believe, I could be wrong :lol:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #459956 2nd Oct 2015 8:52pm
mikeh501
I don't think 110 vehicles have had this since the TDI days. And everyone removes them when they go wrong.
You mean the boge strut?
Post #459958 2nd Oct 2015 8:55pm
mikeh501
Beat me! The boge unit was so they could have softer springs but still carry weight. The boge strut pumed up and takes the weight.
Post #459960 2nd Oct 2015 8:57pm
And used to cause spectacular body roll!
Post #459982 2nd Oct 2015 10:08pm
