Home > Puma (Tdci) > 110 wiper motor check/removal |
Dash out unfortunately. A few pointers here perhaps? It may be just the park switch?
http://www.defender2.net/forum/topic21058....iper+motor http://www.defender2.net/forum/topic38828....iper+motor If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Oct 2015 9:58am |
Crofter Member Since: 19 Feb 2015 Location: Peterhead Posts: 169 |
Thanks that's a good start I can progress with this.
2nd Oct 2015 10:57am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17508 |
You can remove the wiper moter without actually removing the dash, but you do need to remove all the dash fasteners so that you can pull the enture dash a few inches away from the bulkhead. It isn't difficult, but equally isn't a job for the faint-hearted.
I've actually done it in heavy rain at the roadside mid-journey when the wipers conkied out once! All part of the experience that is Defender ownership. |
2nd Oct 2015 11:28am |
That's interesting another option I will probably tackle this with a friend who is a bit more experienced in mechanics than me. Hopefully between the 2 methods we can give it a go.
Thanks |
2nd Oct 2015 11:40am |
Thanks for the help we undid the screws at the passenger side that's the top Torqs, side ones at the door and the underneath one at the foot well checked we had voltage to the motor. My friend noticed rust on the spindle at the passengers side I have been spraying the spindle on the outside with WD40 and the wiper now appears to be working.
Thanks guys for your help. I do not know if I am too impressed with the design having to dismantle so much if the motor requires changing. |
3rd Oct 2015 4:44pm |
