Home > Puma (Tdci) > Adaptor shaft standard or Ashcroft |
philbert Member Since: 18 Sep 2015 Location: Falkirk Posts: 44 |
Hi all just bought my 110 and would like to drop the transfer box and check the condition of the adaptor shaft. I see Ashcroft's are doing a kit of modified parts should I buy the kit or good quality standard parts?
1st Oct 2015 7:22pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Either.
I've done a few now using genuine parts, and there have been no problems. It's only down to JLR doing half a job, that they caused issues... Full kit to replace everything from LR around £160, fit and forget. Can't comment on the Ashcroft kit? But I'm sure coming from them it would be just as good. It's been well documented on here, I did do quite a large post on it. http://www.defender2.net/forum/topic32931....rn+splines 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
1st Oct 2015 7:39pm |
Thanks just read thru your post looks easy enough. Ashcroft kit is about twice the price of standard parts but as you say will probably be good.
I'll speak to my local specialist and see what he suggests. |
1st Oct 2015 8:18pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
My bog standard, ex-factory coupling had imperceptible wear when inspected (and thoroughly greased) at 150k miles during a clutch and transfer box change, so there are certainly some good ones out there.
1st Oct 2015 9:18pm |
alby Member Since: 25 Dec 2014 Location: The Shire Posts: 159 |
Just done the coupling on a mates 110 Double cab. It was on its second coupling at 50000 and 5 years. It's on its second clutch too. Don't know what miles they were done at, but there was certainly signs of someone being there before us doing both jobs.
We fitted the standard parts. I used a high %moly content moly grease that I borrowed from work and used loads of it. The coupling we removed was well worn, several splines had gone completely on the female part, the male part wasn't far off of stripping completely. It was probably only one jerky gerachange away from going completely Mind you it's had a hard life, it was from a shooting estate in the highlands so has spent a lot of time off road with a set of knobbly 265 tyres on. |
1st Oct 2015 9:37pm |
