Home > Puma (Tdci) > 40km check up tomorrow |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 |
Any thing specif I should be checking?
this is the list from the once over that I would like to have them look at...They are a bit nit picking, but what the heck huh? front of crank case drip (very small) rust around the light surrond the ever present water ingress door molding on the both passenger doors (rear) oil spray in the engin bay ( around the brake fluid resevoir) antifreeze coming through the footwell ( heatercore) cold warm heat at times on passenger side ( thanks dgardel for putting up the fix...let's see if they know about it) anything that I am missing and that they should be checking, maybe a fault that hasn't reared it's ugly head? Thanks for all Cheers, John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
21st Nov 2010 1:46pm |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 |
Hello John,
Having read your checklist I noticed the "front of crank case drip (very small)". It seems we might have the same issue and I am going to have it checked this week. If you want you can check my post with details on this issue here: http://www.defender2.net/forum/topic4469.html and tell me if you see the same with your def. Thank you and waiting for your reply Cheers, Mike |
21st Nov 2010 10:28pm |
goog luck Johnnyturbo2002 -- let us know how it goes !
22nd Nov 2010 11:50am |
Hi Mike, much the same as yours, except that it seems you loose a lot more than mine. I just have the very beginnings of something, but I wanted to have it looked at. Chances are they will tell me it is a diesel and it is sweating...( yeah right, gone are those days of the old mercedes sweating..) Thanks for the comprehensive foto shoot that you loaded. John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
22nd Nov 2010 1:02pm |
Hello John,
I would really appreciate it if you could share with me and the other folks here who might encounter the same problem with oil leaking in the front of the crankshaft, what hapenned during your check at the dealer's. What did they tell you and how they fixed it... Thank you very much. Mike. |
29th Nov 2010 6:41pm |
