Home > My Defender > 1988 90 Td5 NAS Replica |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1720 |
Looks so much better with the boosts and minus the A bar, fantastic Defender.
Think I need to get a soft top again, but definitely a td5 |
28th Sep 2015 8:54pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Cheers!
I'm looking to fit some spots on the bumper, but yes I now prefer it with the A bar off. Somehow the silver Boosts work on this 90, and the grey Tornadoes with Montalcino 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Sep 2015 8:57pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
What rag n cage combo is it Martin?
Planning on doing this to the 90. |
28th Sep 2015 9:27pm |
All Wheel Trim hood on a Frogs Island cage - back in the day when no-one else did cages! 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Sep 2015 9:28pm |
This was back in year 2000, other options are now available (not even sure Frogs do it any more
All Wheel Trim are still making hoods though 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Sep 2015 10:19pm |
CE TD5 Member Since: 20 Nov 2014 Location: UK Posts: 51 |
As a NAS replica I think it looked better before, but the boosts and no a bar, do make it look more TD5 era/modern.
I like the way you painted the wing mirror covers and arms body coloured back in 2000, now loads of people do it. I was only 8 in 2000 |
29th Sep 2015 12:49am |
29th Sep 2015 7:02am |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
did you used to by parts from Yardnolds of Stratford Upon Avon?
30th Sep 2015 3:09pm |
Sorry Nick, just seen your question - yes a lot of the parts came from Yarnolds, back in the day
Few jobs crossed off the list... Winter pack is now fully fitted Click image to enlarge Pilkington heated screen fitted and the Puma XS seats wired up. I'm a very happy and warm boy Puma switches were fitted into the existing dash panel using switch carriers cut from a 2002MY Td5 centre console, aluminium strip, a Dremel and plastic welding Had to fix a broken solder joint to the thermal switch inside the driver's backrest but fortunately a relatively easy repair. What you can't see is the totally re-loomed dash cluster, replacing the old spaghetti from incremental retrofits Also fitted a tailgate switch for the courtesy lights, and now it's dark and gloomy I've mounted a pair of spotlights on the bumper with a new loom too - replacing the ones on the A bar I took off a while back. Can anyone spot the other retrofit item? Not easy admittedly on that pic 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Nov 2015 12:09pm |
A tacho, or the XS trim gearknob? !!
I have a question, with the hood and cage combo, do you need the normal soft top pieces for above the screen and doors...I'm so close to getting my 90 NAS topped, though not sure what to order exactly? |
2nd Nov 2015 12:12pm |
Both of those have been fitted for some time.
Yes you need the windscreen rail and door surrounds. Not particularly clear but Click image to enlarge Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Nov 2015 12:20pm |
thought I recognised it. I used to work in the parts department when it was yarnolds
2nd Nov 2015 12:25pm |
Cheers Martin, I really want to go with the Rovers North type top..
Though it seems these don't have the door surrounds.. http://www.roversnorth.com/ProductDesc.asp...amp;key=it |
2nd Nov 2015 12:40pm |
Haha small world 1988 90 Td5 NAS soft top
2015 D90 XS SW |
2nd Nov 2015 12:41pm |
