Home > Maintenance & Modifications > Where does the Jack foot plate live? |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
When I had the 90 it was directly behind the cubby box, along with the jack in its bag and a thick rubber band across the bracket, around them both. If that makes sense? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
28th Sep 2015 5:16pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Was that a non bulkhead car too? Did the footplate sit on the floor panel behind the cubby, sticking upwards?
Was that bracket screwed or riveted in position? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
28th Sep 2015 5:18pm |
As above directly behind the cubby box. The bracket was not screwed or riveted. The weight of everything else sitting on it together with the band kept everything in situ. If you go through life with your head in the sand....all people will see is an ar5e!!
28th Sep 2015 5:24pm |
The jack and foot plate are tied up together and are mounted under my 2nd row seats. Don't have the truck on hand here now, but know that when I push the 2nd row seats forward down, the jack does not sit in the way of a flat floor.
Eric Edit: see only now you talk about a 90. Mine is a 110 of course, so different storage. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
28th Sep 2015 5:25pm |
Should I have one of these in my 2011 Defender?
It's just got the jack. |
28th Sep 2015 6:17pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Depends on what jack you've got. If it is the tall pilar type then yes, it should have a foot plate. If it is the small bottle jack, then no, you don't need anything else to go with it. BTW, mines is mounted on the bulkhead between the seats, but if yours doesn't have a bulkhead then I've no idea where it would go.
28th Sep 2015 6:40pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Swap it for the later bottle jack and put it under the passenger seat
28th Sep 2015 6:43pm |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 |
Directly behind the cubby box as the others have said with a thick elastic band holding it all in place. Mine does have a tendancy to rattle though - I keep meaning to sort out some rubber matting underneath to stop that.
28th Sep 2015 7:17pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2079 |
Sorry - unable to upload photo....
The bracket is mounted horizontally directly behind the cubby box, in a channel on the centre line of the cab. My bracket is fixed down with one screw. The jack foot clips onto it and Is quite secure when driving. The awful Landrover screw jack sits over/across it in its lovely bag, fastened down by two ratchet straps fitted to the same channel as the foot bracket. This makes sense when you are looking at it! I'll try and get a photo. Having said that, I agree that the jack is a pile of poo and you should invest in something else! |
28th Sep 2015 7:19pm |
Great. Got it. Thanks chaps.
I've put it back and put a piece of rubber mat under it to prevent rattles and vibration. I've got a bottle Jack too but the handle is 6 inches long! 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
28th Sep 2015 7:31pm |
