![]() | Home > Maintenance & Modifications > Cruise Control Install |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 ![]() ![]() |
That is almost the same as what I did.
A well thought out guide that will help others doing this little job ![]() Only some slight differences on my set up(to give options)... I cable tied the control box to green module close to where you put yours. For the ignition live I used the feed to the wiper switch as it was a bit easier on mine to get at. Dash cluster speedo wire is as said pin 13, I sent this picture to Mobile Centre at the time... ![]() I fitted my stalk on the left... http://www.defender2.net/forum/post450464.html#450464 Cheers, Kyle. |
Great write up
![]() My install pretty much the same except I used heat shrink / solder connections I took the ignition feed from the white wire on the ignition barrel I took the speed sensor from the transfer box instead of the dash cluster Took about 2 hours to plan, 4 hours to install Great modification |
Great mod, yes......... for the courageous.
![]() And not much of a reason for me to install one, because 90% of my travel is local here and there is not a stretch of more than 500 m before the limit will change to something else. ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 8th Sep 2015 5:10am. Edited 1 time in total |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Have fitted 3 kits now to past and present Defenders,,
First one, on a 2009, gave problems when taking the speed pulse from behind the dash, as too weak, and would just not set up,,,,so was taken direct from the gearbox, All have been fitted the same way for the speed input since, First kit took a while, as that also had to be spliced into the throttle module,, (still have if anyone wants to make a offer !!) later MC kits, 2 hours max California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Is it possible to take a RPM instead of a ground speed reading? Just wondering if you could use it as an engine speed governor whilst stationary.
Checking autoscout.ch this morning found a very nice Def cabrio by Avus for sale. Has a very neat cruise control installed, and going by the name on the stalk, I found the supplier of those which is Swiss. Gonna check this out some time... Here is a few pictures. Anybody maybe know this one, opinions? Seems very similar as the stalk installed by jimz.
Eric ![]() ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 ![]() ![]() ![]() |
Supplier in Holland see link - http://www.johngold.nl/eng/cruise-control_eng.htm# NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
jimz Member Since: 01 Mar 2015 Location: Horsham, Sussex Posts: 128 ![]() ![]() |
looks exactly the same to me but with a name on it, prefer mine without.
Mine it's better
![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Need a quick bit of help...
Purple wire; ![]() Click image to enlarge Which wire on the clutch switch do I splice into, Black or Black/White? Cheers Yan |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
thanks - bookmarked for future use! My 90 Project : http://www.defender2.net/forum/topic52774.html
I took the speed sensor from the gearbox like TJ, I was not brave enough to cut into the multi-wire loom that fits into the dash-pod - way to delicate for my mits
I found the white ignition live on the ignition switch easy enough (at first i though it would be a pain but was easy!) other that that, i fitted mine the same way - been running it for 3-4 years now and it's staying on the truck |
Resurrection
![]() Just fitted the Mobile Centre cruise control - easy but a bit time-consuming job and great instructions (though when setting up, the final beeps were low not high...works fine though). Brake pedal connection to Y harness is pretty tight but some rough handling did the trick ![]() I mounted it on the left as it's left hand drive and it's really comfortable. Thanks to Mobile Centre for the support and quick delivery (driving across Spain in the next few weeks ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
