Home > Td5 > Gearbox soundproofing |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
I was thinking of this myself, however, I can see one problem and that is the fact of moulding it to the contours of the shroud.
Dynamat is very versatile but I recon it'd be difficult and if you did best to take the shroud out and do it in your home r similar than fiddling in an awkward position for ages. I think it can be done though, just not easy... Maybe horizontal or vertical strips applied one at a time moulded in with roller and heat and then tape all of the joins. Wouldn't be pretty but so what, it's a gearbox should 99.9% of the time hidden. |
23rd Sep 2015 6:32pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
Dynamat does NOT sound proof anything!!! It simply stops vibrations and as the gearbox shroud has lots of different curves in it, it shouldn't rattle. I however did fit a layer of closed cell foam which has two benefits, one is it cuts out some noise and also stops some heat coming through from the gearbox area which can happen on long journeys with the drivers window open. Another trick to stop gearbox noise on a td5 is to fit a discovery 2 gearbox cover (which sits on top of the gearbox itself) and if you want to see pics I have a few in my build thread. Ray
23rd Sep 2015 7:35pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
23rd Sep 2015 7:59pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
So the gearbox cover that's currently on is different?
23rd Sep 2015 8:28pm |
And what about dash out and dynamat the bulkhead? Worth it?
I've done the tub and arches and the difference is very noticed. In fact I can now hear other squeaks and whistles from the front of the cab |
23rd Sep 2015 8:31pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Inside my gearbox cover was already a nice layer off foam. Looks standard to me.
I tried to find the picture off the disco cover but didn't find it. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
23rd Sep 2015 8:34pm |
isacs, which model? tdi, td5, tcdci? My 109 thread
my youtube channel |
23rd Sep 2015 9:38pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
Best thing for that area is Wright Off Road mat set.
Talk to Drew direct and he will sort you out a good price. |
23rd Sep 2015 9:49pm |
Here's the pic Click image to enlarge It sits on the top of the gearbox here Click image to enlarge And here's a poor pic of it in place Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
23rd Sep 2015 9:57pm |
The tub and arches when covered in Dynamat makes a big difference because they are large flat panels which vibrate and rattle a lot while the car is moving so the deadening material makes the vibrations a lot less noticeable. Adding a layer of closed cell foam will cancel out some noise too. As for the bulkhead there are a few flat areas so it will make a little difference but not a massive one, the footwells is a good area to cover and filling the big hole in the passenger footwell (if you don't have aircon) will cut down on engine noise. Ray My build thread http://www.defender2.net/forum/topic17615.html |
23rd Sep 2015 10:05pm |
It's a 90 csw
23rd Sep 2015 11:12pm |
G-mack. It's a TD5
24th Sep 2015 6:55am |
cool then rays suggestion for the bell housing soundproofing would be first thing to do. loads of them on ebay for £20 ish quid, My 109 thread
24th Sep 2015 3:21pm |
Does covering the bell housing make any difference?
24th Sep 2015 4:10pm |
