- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > Loadspace mat 90 v 110 |
Romadog
I have one in my 110. As long as you have flat top wheel arches ie. no rear seats then it will go, with a bit of cutting to go round the filler pipe as its in a slightly different position to 90. Then the piece you cut out goes in the gap left for 90 filler.
I also punched holes through for tie down anchor points. These hold it in place along with the sticky strips already on the underside of the mat.
21st Sep 2015 6:45pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
