Home > Puma (Tdci) > Adaptor Shaft!
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Adaptor Shaft!
My Defender I having its annual service at home. I do about 6k a year in her, but I always change all the oils as it is a good indication of what I going on inside.
Long and short the intermediate shaft O-rings have gone on the transfer box, so whipped it off t sort. The wise man at this point will change the adaptor shaft. (52,000 miles on original). Jesus wept, God knows how the hell it hasn't give up before now?
Question is: how do I get the female part of of shaft of of gearbox? Do I need need lock it, or, would a windy gun shock the nut loose?
After the nut free, how do I get the female part off slide hammer or pullers?
Any thoughts?
Kevin
Post #456740 21st Sep 2015 10:06am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
A good 3/4" air gun will whiz that off. Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #456745 21st Sep 2015 10:12am
Rickydodah
When mine was changed a large thick washer was welded on the end of the coupling and a nut welded to that. The threaded end of a large, very large slide hammer was screwed into the nut. Thumbs Up I started with nothing and still have most of it left!
Post #456752 21st Sep 2015 10:38am
The 'official' procedure requires the use of a holding tool which bolts onto the back of the gearbox and engages the two slots in the periphery of the female part to stop it rotating. A windy gun may work, but (and this is just my view) I am a little uneasy at the thought of the reaction to the windy gun being taken by the gearbox, clutch and crankshaft.
A further issue which you may have if not using the proper tool is holding the part when torquing the retaining setscrew down after fitting the new part.
Once the setscrew is removed, the female part of the coupling may just slide off, but more often you'll need to use a puller.
The manual says that the replacement part should be heated to expand it slightly prior to fitting, but again you may find that this is not necessary (if I recall correctly the manual says heat to 100 Celsius, so not difficult to do if you have to).
The holding tool is 308-701 "Locking Fixture Output Flange" and is available from Bosch Automotive, though it is really difficult to buy from them if you're not trade (it took me an age to get an account set up)!. The tool looks likes this, and wouldn't actually be difficult to fabricate:-
Post #456754 21st Sep 2015 10:43am
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
I spent yesterday doing the exact same job on a friends Puma 110 dcpu.
we split the transfer box and gearbox to change the oil seal and do the adaptor shaft at the same time.
Like the OP it was good we did, as the adaptor shaft and cup were well tired. Had already lost three splines which had gone completely.
The screw wasn't that tight, didn't need to use a windy gun, just a socket and breaker bar and undid the screw with the box in 6th.
the female coupling was a right pain to get off of the gearbox shaft, it was very very tight. used a bearing puller to remove it.
Have found that the new female part won't go back on the end of the gearbox now either.
We heated it to 100, no joy, then to 120-130 degC and it still would not go on.
re-checked the splines with a magnifier for damage and they're ok and spotless clean.
We reheated the coupling and got it to go on with persuasion from a soft faced hammer.
got it to within the last 10mm and it stuck (it was cool by this time though)
Attempted to gently heat it but was worried about the oil seal on the gearbox.
Attempted to use the old screw to draw it on, but was only two to three turns of thread inside the shaft so was very wary of beasting it and it still didn't budge. in the end we drew the coupling back off with the pullers and called it a day as it was dark, late and we were tired and fed up so gave up for the day.
going to give it another go this evening.
Post #456796 21st Sep 2015 1:28pm
Kevzeboy
Job sorted!
Key points:
The big nut came of by popping her in reverse and a good bat with a windy gun to set her free.
Female par of the adaptor shaft came off with a good set of hydraulic pullers.
After the output seal was changed; I hot the new female part of the shaft on by greasing the end slightly, it had been sat on top of the combi boiler for a few days and was nice a warm, not hot. It went a third on, to get her home, I cleaned the old male part of the shaft and use it as a knocking tool. It worked a treat!
I only wish getting the transfer box back one was as simple.
I am glad I did it. It has taken all of the slop out of the transmission and I have fixed an oil leak too! A small fortune saved and we have averted a brake down, by incorporating it in to her annual service!
Please feel fr to get in touch if you would like to know any more about how to do the job!
Kevin
Post #458839 28th Sep 2015 9:47pm
philbert
going to tackle this job Thursday - Friday is there a pictorial anywhere?
Post #460804 5th Oct 2015 9:37pm
ian series 1
There was...but all my photos disappeared! Sad 80" 80" 86" 88" 90"
Post #460808 5th Oct 2015 9:42pm
theorangebandit
Fitted my new clutch a few months ago now and really wanted to fit the Ashcroft shaft at the same time but I was too poor and that hasn't changed yet either. Needs doing though its quite loose. I greased and refitted. Quite jealous of you lot doing yours 😞
Post #460811 5th Oct 2015 9:46pm
philbert
yes I noticed all the pics were missing .
just thought id ask in case there is another pictorial available.
Post #460838 5th Oct 2015 10:23pm
Forestman1
Sweden 2011 Defender 110 Puma 2.4 SW Galway Green
Going to change my output shaft and wondering if we need to change both the oil seals on each side:
Transfer box input shaft oil seal: ICV100000 and Gearbox output oil seal LR0058800 ?
We are also a bit worried up here about doing the job without the flange drive holding tool. Defender 110 SW S, 2011, Galway Green
Post #576286 8th Nov 2016 5:23pm
Forestman1
BEWARE OF CRACKED SPACER ON OUTPUT SHAFT CENTER BOLT!
I started the job today with replacing my output shaft with the Ashcroft MT82 kit.
No problems until we mounted the center bolt back into the new flange.
At 133 Ft Lbs the spacer cracked all around the bolt. (picture)
When we pulled the spacer apart we could see that those cracks were old
and must have been there for a longer time. The Defender had this
output shaft failure once before at 20000 km and maybe the bolt was damaged
already at that time during the mounting. (Made by LandRover, Sweden)
Now we solved this situation by putting in another spacer leaving enough
grip for the bolt. (We DID check that the flange was in the correct position
heated to 100 C and cautiously knocked in place.)
Maybe it is a good thing to order a new center bolt too
when replacing our output shafts!!
The replacing job is not done yet and will continue tomorrow. Defender 110 SW S, 2011, Galway Green
Post #579199 20th Nov 2016 5:04pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Without the special tool, how would you guys torque the nut to the correct spec?
Will put the gearbox in 6th suffice?
And also which puller is good?
Thanks
Post #654786 4th Oct 2017 10:35am
Although I know of people who have just put the box in gear, it is not a technique I would like to use (especially not if an ipact wrench is going to be used). It is a very expensive mistake - far more expensive than the right tool - if it breaks. It would, incidentally, hold better in a low gear than a high gear, you're less likely just to spin the engine.
I've heard of people using large Stillsons to hold the 'cup', I've heard of people welding things to the 'cup' to hold it, and whilst these might be OK to remove a faulty one I wouldn't do either to a new one.
It is not especially difficult to fabricate something to do the job of the right tool if you can't get hold of the genuine thing.
Forestman1 wrote:
... At 133 Ft Lbs the spacer cracked all around the bolt. When we pulled the spacer apart we could see that those cracks were old and must have been there for a longer time. The Defender had this output shaft failure once before at 20000 km and maybe the bolt was damaged already at that time during the mounting...
I wuldn't mind betting that when the part was last changed, the bolt and spacer/washer was used to force the 'cup' onto the gearbox spigot without the 'cup' being preheated, and the spacer/washer cracked as a result and has probably been broken ever since.
Post #654791 4th Oct 2017 10:51am
