Home > Technical > Servo or vac pump?
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Servo or vac pump?
hi all, ive just rebuild a c reg 110 and the brakes are rock hard, and the pedal doesnt sink on startup, there is suction being created -1bar when i tested on a guage. no idea how much i should have/ need. with the engine stopped the servo does hiss a little but nothing much. any advice cheerrs chaps
Post #456651 20th Sep 2015 9:43pm
Rickydodah
I'd have said anything in excess of 0.5 negative bar would be sufficient to work the servo. What's it like if you keep your foot on the brake and allow the vacuum pump to build up a good head? Confused I started with nothing and still have most of it left!
Post #456677 20th Sep 2015 11:51pm
Cupboard
You're never going to get more than -1 bar gauge vacuum pressure, at least not at sea level.
You might do in a submarine, but you're limited by atmospheric pressure of about 1 bar. Remove all the air and you've just got the atmosphere pushing in.
Post #456781 21st Sep 2015 12:48pm
g-mack
so you are checking the vacuum from the pipe that enters the servo yea? and you can here hissing in servo? i would say its the servo thats gone!
if your getting -1bar at pipe just before entering servo the pipe and vac pump are probably fine.
this of course is MHO Thumbs Up My 109 thread
my youtube channel
Post #456815 21st Sep 2015 2:24pm
jst
Change the servo. Get a disco one in there from disco with abs, it's bigger, better for repeat braking Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #457836 24th Sep 2015 8:12pm
donmacn
Thread resurrection!
On my 300tdi 110 the brakes 'aren't wonderful'. On checking at the monent, the pedal doesn't drop when the engine starts, so I'm going to be looking at issues with the servo/vacuum pump/hose.
The car is 24 y/o and I'd have to wade through a lot of paperwork to see if the pump was ever replaced. I know I did the servo myself, but that could be several years ago.
So, the point of reviving this old thread - is the suggestion above to use a Disco servo still valid? Is it an easy fit, and does anyone have a part number??
D Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #725426 26th Aug 2018 11:14am
jst
its a direct replacement and something we fit on off roaders and autos as a matter of course. the bearmach std def replacement one will also do the job as will an ABS one from defender or Disco tdi. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #726217 30th Aug 2018 7:04am
zsd-puma
Sounds like the servo, buy a cheap vacuum pump (mityvac or similar) and connect to the servo, you can put a vacuum to it manually and see if the servo works - obviously it'll only work once before you use the vacuum up and have to pump it again. If you can't make a vacuum your servo is leaking.
Post #726317 30th Aug 2018 7:30pm
donmacn
Thanks guys,
I did own a Disco 2 way back when, but it was brand new and only had it for a few months. I'm sure I must have, but I don't really remember looking under the bonnet much - are we talking all models of Disco for this, or up to a particular model?
ZSD - thanks for that - a good plan, and I never know such testers existed. The mityvac look a wee bit pricey for something I might only use once. Do you reckon this would do the job?
https://www.amazon.co.uk/dp/B07F7XXMQG/ref...9f427e8ea3 Donald
in the past..
Post #726335 30th Aug 2018 8:28pm
zsd-puma
Genuine Mityvacs are really expensive, but there are plenty of generic ones. That Amazon one will be ok, it might not last long but it'll do the job for now.
Post #726350 30th Aug 2018 9:04pm
donmacn
Well, I might get a vaccum pump for future use, but had a chance today to take a closer look.
The vaccum pump on the car is definitely working. With the pipe disconnected from the servo I could hear it chuffing away, and it would pull my thumb quite tightly onto the end of the pipe. For a pressure of -1bar (I think, roughly??) I suspect it's OK
The servo? Visibly cracked along the bend in the pressing by both master cylinder bolts. I've also realised that my 'spare' in the garage is also split. So, temporarily fixed the current one with some 'dum dum' and gorilla tape, and I can feel a difference. Not a startling difference, but a definite improvement.
So the question is which is the best servo to get that would fit onto the standard pedal box and master cylinder? That would be the 'easy' option. If there were another servo which would give significantly better assstance, but which would need the brake lines to the master cylinder remade, then I'd consider that. Donald
in the past..
Post #726797 2nd Sep 2018 6:08pm
zsd-puma
You could probably take them to bits and weld the crack back up.
Post #726860 2nd Sep 2018 10:11pm
donmacn
^^ Never thought of that Thumbs Up
Have you tried this? When you say 'take them to bits' do you mean taking the servo itself to bits? First glance I'd have thought this would be a little tricky as they seem to be a 'press and tab' manufacture. But I can see how a line of weld along the crack might well work.
Still though, my wife's car is a Skoda Yeti. Going from that into the Defender, the Def brakes are really poor. If there's a fairly straightforward way to improve them I'd think about it. Donald
in the past..
Post #727020 3rd Sep 2018 6:36pm
zsd-puma
I've not looked closely at Defender servos, and an 80's one may not be the same as my Puma. But I have rebuilt a 90's Mini one. It's a kind of twist the two halves and it pops apart thing, It's not threaded as such, it's more like a bayonet with wedges on it.
You might be able to just weld it from the outside. The heat should be far enough away from the diaphragm not to harm it, at the end of the day you haven't got a lot to lose if it doesn't work.
Post #727031 3rd Sep 2018 7:51pm
