Home > Puma (Tdci) > Fuel consumption 2.2 MY15
Hanechdene
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi there
Does anyone have any thoughts on the fuel consumption of my 2.2 I can only get 250 miles to the tank. It is on Goodyear MTR tyres.
Thanks for any suggestions.
Lucinda Confused
Post #447829 20th Aug 2015 8:22pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I'm guessing that's about right. Should have bought a 110 or 130. Larger fuel tank! Mr. Green
Post #447836 20th Aug 2015 8:39pm
Gaz
United Kingdom 1994 Defender 110 300 Tdi HT Pennine Grey
Hi i do longish runs and get about 340 a tank, mines a 2012 90 2.2 hard top on continental at tyres with 25,000 on the clock.I run on normal diesel normally shell or bp .I do not drive slow quite the opposite i wind it up through the gears and this also gives smoother gear changes too.iIve worked the mpg at between 29 to 32,which is a lot better than my old td5.Maybe it will get better with more miles.The mt tyres will make a slight difference due to the extra drag. Talking of drag the handbrakes not binding is it?
Post #447856 20th Aug 2015 9:25pm
Martin
Site Admin
I started a thread about this last week
http://www.defender2.net/forum/post444813.html#444813  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #447859 20th Aug 2015 9:32pm
SS90
A lot really depends on how the vehicle is driven, it also makes quite a bit of difference whether you're doing short journeys or not. I tend to never go over 60mph, they can really drink the fuel, hardly surprising when they're basically a brick with wheels on Laughing
Post #448395 22nd Aug 2015 11:00pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
As a rule of thumb I've experienced this to be true on my MY14 90:
100 km/h - 10 liters on 100km
110 km/h - 11 liters
120 km/h - 12
and so on...
It doesn't really drop much below 9-9.5l for 100km and about 10l with my roof top tent on. But it doesn't go up either if you're staying below 100km/h. Then you can drive about anything (steep alpine mountain roads, short distances etc.) without really affecting the mileage. Must be the famous Defender magic Bow down Laughing
Post #456063 18th Sep 2015 12:12pm
Rallymental
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
So what should I be realistically be expecting from a tank in the 110 (2.2 my15 xs sw)?
Post #456067 18th Sep 2015 12:47pm
Rallymental
Did that make sense???
You know what I mean!
Post #456068 18th Sep 2015 12:48pm
thor44
I don't know about the fuel consumption of a 110, but realistically speaking I would expect a range of 650 to 700km referring to the consumption of my 90. On mine I get about 500-550km per tank (57l), but keep in mind that 60% of my mileage consists of my flat 10km to and from work and about 40% on alpine roads and my highspeed is about 80-90 km/h keeping the revs mostly between 1500 and 2500 rpm. No autobahn or whatsoever in the daily use of my trusty Landy. Wink
Post #456105 18th Sep 2015 3:01pm
Nipalong
England 2015 Defender 90 Puma 2.2 SW Corris Grey
I do long runs in my 65 plate 90SW and do around 32mpg
Post #456619 20th Sep 2015 7:41pm
Pickles
How much "to a tank", is a pretty vague measurement. I mean,how far to empty are you going to go before you fill up to work out your "tank full"...not very accurate at all.
The only way to measure accurately is fill up, take your mileage, let it go to say 400ks, 250miles, or whatever, and then fill up again, & take the mileage reading,.....that will give you a truly accurate reading.
We normally average between 29-31 MPG.
Pickles.
Post #456668 20th Sep 2015 10:11pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
28MPG in my 15 Plate 110 on a 200 mile motorway run compared with my 30 year old 90 (200TDI) getting 37MPG on the same run... DPFs save the environment? Censored !
Post #456685 21st Sep 2015 1:42am
thor44
Pickles.
Hi Pickles. You're absolutely right. "per tank" for me is pretty much after the fuel light comes on and referring to the gas pump this means at about 49 - 50l of fuel consumption. So, my MY14 90 averages in at 9 - 9.5l for 100km during daily use.
Post #456702 21st Sep 2015 6:20am
mk1collector
We get roughly 420 miles a tank (till light comes on) out of our 64 plate 110 double cab. Ray
My build thread
Post #456735 21st Sep 2015 8:30am
mse
The tyres wont help either, MTR, ATR, Road probably 1-2mpg between them, muds being the worse Mike
Post #456751 21st Sep 2015 9:38am
