Home > Puma (Tdci) > Fuel consumption 2.2 MY15 |
Hanechdene Member Since: 18 Sep 2014 Location: High Wycombe Posts: 62 |
Hi there
Does anyone have any thoughts on the fuel consumption of my 2.2 I can only get 250 miles to the tank. It is on Goodyear MTR tyres. Thanks for any suggestions. Lucinda |
20th Aug 2015 8:22pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
I'm guessing that's about right. Should have bought a 110 or 130. Larger fuel tank!
20th Aug 2015 8:39pm |
Gaz Member Since: 18 Jan 2015 Location: Midlands Posts: 29 |
Hi i do longish runs and get about 340 a tank, mines a 2012 90 2.2 hard top on continental at tyres with 25,000 on the clock.I run on normal diesel normally shell or bp .I do not drive slow quite the opposite i wind it up through the gears and this also gives smoother gear changes too.iIve worked the mpg at between 29 to 32,which is a lot better than my old td5.Maybe it will get better with more miles.The mt tyres will make a slight difference due to the extra drag. Talking of drag the handbrakes not binding is it?
20th Aug 2015 9:25pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
I started a thread about this last week
http://www.defender2.net/forum/post444813.html#444813 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Aug 2015 9:32pm |
thor44 Member Since: 18 Sep 2015 Location: Ahrntal, Südtirol Posts: 128 |
As a rule of thumb I've experienced this to be true on my MY14 90:
100 km/h - 10 liters on 100km 110 km/h - 11 liters 120 km/h - 12 and so on... It doesn't really drop much below 9-9.5l for 100km and about 10l with my roof top tent on. But it doesn't go up either if you're staying below 100km/h. Then you can drive about anything (steep alpine mountain roads, short distances etc.) without really affecting the mileage. Must be the famous Defender magic |
18th Sep 2015 12:12pm |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 |
So what should I be realistically be expecting from a tank in the 110 (2.2 my15 xs sw)?
18th Sep 2015 12:47pm |
Did that make sense???
You know what I mean! |
18th Sep 2015 12:48pm |
I don't know about the fuel consumption of a 110, but realistically speaking I would expect a range of 650 to 700km referring to the consumption of my 90. On mine I get about 500-550km per tank (57l), but keep in mind that 60% of my mileage consists of my flat 10km to and from work and about 40% on alpine roads and my highspeed is about 80-90 km/h keeping the revs mostly between 1500 and 2500 rpm. No autobahn or whatsoever in the daily use of my trusty Landy. |
18th Sep 2015 3:01pm |
Nipalong Member Since: 08 Jul 2015 Location: Kent Posts: 29 |
I do long runs in my 65 plate 90SW and do around 32mpg
20th Sep 2015 7:41pm |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3783 |
How much "to a tank", is a pretty vague measurement. I mean,how far to empty are you going to go before you fill up to work out your "tank full"...not very accurate at all.
The only way to measure accurately is fill up, take your mileage, let it go to say 400ks, 250miles, or whatever, and then fill up again, & take the mileage reading,.....that will give you a truly accurate reading. We normally average between 29-31 MPG. Pickles. |
20th Sep 2015 10:11pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 299 |
28MPG in my 15 Plate 110 on a 200 mile motorway run compared with my 30 year old 90 (200TDI) getting 37MPG on the same run... DPFs save the environment? !
21st Sep 2015 1:42am |
Hi Pickles. You're absolutely right. "per tank" for me is pretty much after the fuel light comes on and referring to the gas pump this means at about 49 - 50l of fuel consumption. So, my MY14 90 averages in at 9 - 9.5l for 100km during daily use. |
21st Sep 2015 6:20am |
We get roughly 420 miles a tank (till light comes on) out of our 64 plate 110 double cab. Ray My build thread http://www.defender2.net/forum/topic17615.html |
21st Sep 2015 8:30am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
The tyres wont help either, MTR, ATR, Road probably 1-2mpg between them, muds being the worse Mike
21st Sep 2015 9:38am |
