Home > Technical > bearmach or genuine LR output seals.
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
As title really. Need to do the output seals on my transfer box and as I'm going to do the oil I may as well do it now. I JUST don't know which brand seal to get or if it's worth changing bearings etc when I do it or just the seal. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #454039 10th Sep 2015 9:20pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
I have always found Corteco seals to be good...and if the is no play or noise in the bearing I would leave it alone.
You may need to change the flange too if its showing any signs of wear, otherwise the seal will not seal properly.
N.
Post #454082 11th Sep 2015 7:24am
rallysteve
Corteco are OEM for a number of car manufacturers so you are okay going for them. Often the bearmach OE spec seals are corteco. 02' 110 TD5 Double Cab Rebuild Thread
Post #454087 11th Sep 2015 8:19am
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Bearmach ones are corteco!
Post #454109 11th Sep 2015 9:54am
