Home > Technical > bearmach or genuine LR output seals. |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 817 |
I have always found Corteco seals to be good...and if the is no play or noise in the bearing I would leave it alone.
You may need to change the flange too if its showing any signs of wear, otherwise the seal will not seal properly. N. |
11th Sep 2015 7:24am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2222 |
Corteco are OEM for a number of car manufacturers so you are okay going for them. Often the bearmach OE spec seals are corteco. 02' 110 TD5 Double Cab Rebuild Thread
11th Sep 2015 8:19am |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 82 |
Bearmach ones are corteco!
11th Sep 2015 9:54am |
