Home > Puma (Tdci) > 2.4 starter replacement. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Dust in the eyes job on them
Easy to change though, just a lot in the way! Only 2 bolts on the starter, you'll find one has a smaller threaded top to it, that Takes a 10mm nut, this is to hold part of the loom in place. The starter simply sits in place on top of the bell housing with a foam gasket. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
8th Sep 2015 10:26am |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
done this some time ago, so from the head
Nothing complicated, a bit of from-the-top and from below, mainly depending on feeling and size of your hands when 'blind' reconnecting the cables to the starter. First of all, disconnect battery. then the solenoid cable, the main 12v+ feed (if i remember there are 2 cables on this connection, don't forget to fit the small one at installation) Main cable will resist a bit to come off/put aside. then dismantle starter from car 2 or 3 nuts (don't remember) Clean all clutch dust from bellhousing, as it will kill your new starter mount started in reverse order. You'll need soms extensions to reach all the bolts and nuts so have your set ready. When tightening the main cable it is always a good idea to put a second key on the inside not to prevent the stud turning and ripping off wires in the starter. don't overdo it. sure someone will tune in with a step by step picture tutorial explaining it better |
8th Sep 2015 10:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17240 |
Are you sure that it is the starter at fault, since the symptoms you described are more uisually attributable to either the passive immobiliser misbehaving or a poor connection on the main and/or ignition relays under the drivers seat (the latter usually characterised by the temp gauge indiicating maximum).
Generally these are easier to address than the starter which isn't very accessible. |
8th Sep 2015 1:31pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
Just spent 16 days in hospital and on daily visits for antibiotic drips I felt tackling this was out of my comfort zone. Dropped car off at GEMM yesterday morning and collected it today and all I can say is the engagement and speed and smoothness are in a different league. It wouldn't even spin in the vice. Get yours changed if it is at all lazy or clicking occasionally. £80 to fit which i thought was a great price too? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
30th Sep 2015 11:17pm |
Glad it has worked, and that seems a very reasonable price for fitting.
1st Oct 2015 9:59am |
