![]() | Home > Off Topic > What is the best primer for aluminum? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've always used an etch primer (had good results with PPG)
And never had any adhesion problems. ![]() Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20717 ![]() ![]() |
Yes, etch primer.
You may wish to use a fine hi-build primer on top though as I find etch primer rather 'absorbant' so takes up the paint more than you'd expect. I have always just made sure I've had more paint on hand. All depends on how you lay it down too. My sub grille was cast Alu: ![]() Click image to enlarge Not a great quality photo but it's been brilliant no problem at all. I use Autotek etch but each man has his own preference. |
