Home > Technical > prop shaft uj
srod
prop shaft uj
I took my rear prop shaft off today after noticing some play in the uj on the rear diff end.
Once it was off, it was possible to observe free movement, but slight play on one axis; whilst the other axis was very stiff.
Taking apart the joint I find this:
Bearing on right is totally dry, and well worn on the spider.
On a scale of 1 to 10 how Censored is this? Can't understand how the joint can be that dry, and stiff, yet still actually work.
Been noticing a slight rattle/clanking noise when accelerating hard in low gears, or towing in low-range up hill. Hoping this is it.
Cheers,
Shane.
Post #451595 2nd Sep 2015 8:34pm
Retroanaconda
New UJ time Smile
Post #451598 2nd Sep 2015 8:38pm
srod
Cheers! Very Happy New one on order!
10 - seriously? Think: 1 = new, 10 = worst ever seen/seconds away from total failure...
Post #451602 2nd Sep 2015 8:44pm
Retroanaconda
Well perhaps not 10.
But really a UJ, once removed, is either f***ed or it's not - as you're not going to put it back on unless it's perfect.
Post #451611 2nd Sep 2015 9:07pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Retroanaconda wrote:
10
New UJ time Smile
What's this then?
Post #452250 4th Sep 2015 5:29pm
Retroanaconda
Also f***ed!
Post #452286 4th Sep 2015 7:19pm
Timo K
Finland
How's this? Swapped it for a new one today...
Post #452328 4th Sep 2015 8:58pm
srod
So I showed mine to an ex-mechanic friend who rated mine an 8, but those look way worse!
Replaced it with a GKN part I got off ebay for £13.69. Rattle now cured! A nice straightforward, satisfying job with a positive outcome! Thumbs Up
Post #453916 10th Sep 2015 12:22pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
If that is off your own vehicle then you should go and stand in the corner and hang your head in shame. That is terrible and must have been bad for a long time, not the sort of thing you could ignore for very long unless you have absolutely no mechanical sympathy.
Post #453952 10th Sep 2015 3:20pm
