Home > Wheels & Tyres > Tyre pressures
Grockle
Tyre pressures
'ere have any of you got a sticker in the drivers door shut regarding the above 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #44882 10th Nov 2010 4:02pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Just in the manual I think.
30PSI front, 48 rear unloaded for a 110. Not sure for a 90. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #44883 10th Nov 2010 4:13pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Pressures in manual.
30psi Front, 38psi Rear unloaded - 90
Post #44903 10th Nov 2010 7:41pm
BigMike
i run mine at 30 f 35 r on road, take off 5 psi for offroad
Post #44911 10th Nov 2010 8:29pm
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I've got a placard, here in Aus.
It's inside the drivers door, but I can't remember if it's on the B Pillar or door itself?
Post #44931 11th Nov 2010 4:50am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Hi
Just checked my manual and it says the following.
what about 235's - should it be at 35 or 38?
Model - Tire size Front Rear
90 - 205/80 R16 1,9 bar 2,6 bar 28 lbf/in! 38 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm!
90 - 265/75 R16 1,9 bar 2,4 bar 28 lbf/in! 35 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! BM52
Post #44999 11th Nov 2010 11:19pm
WelshGas
Extract from Handbook.
http://topix.landrover.jlrext.com/topix/se...5962/index
Production options weight
The combined weight of options installed which weigh in excess of 1.4 kg (3 lb) more than the standard items that they replaced, and are not already considered in kerb or accessory weights. Items such as heavy duty brakes, high capacity battery, special trim etc.
Vehicle capacity weight
The number of seats multiplied by 68 kg (150 lb) plus the rated amount of load/luggage.
Maximum loaded vehicle weight
The sum of kerb weight, accessory weight, vehicle capacity weight, plus any production option weights.
Rim
The metal support for a tyre, or tyre and tube, upon which the tyre beads are seated.
Tyre pressures
Bead
The inner edge of a tyre that is shaped to fit to the rim and form an air tight seal. The bead is constructed of steel wires which are wrapped, or reinforced, by the ply cords.
TECHNICAL SPECIFICATIONS Wheel specifications
Wheel type
Wheel size
Tyre size
Alloy
7.0J x 16
235/85 R 16
Steel
6.5J x 16
7.50 R16C 7.50 R16
Steel
6JK x 16
205/80 R 16
Steel
5.5F x 16
7.50 R16C 7.50 R16
Steel
5.5J x 16
205/80 R 16 7.50 R16
Loading conditions
Tyre size
Pressure KPa/bar/psi
90 models All operating conditions.
Front Rear
All All
207/2.1/30 262/2.6/38
110 models Normal conditions
Front Rear
All All
207/2.1/30 331/3.3/48
110 models Vehicle loaded to gross maximum weight, and/or when towing
Front Rear
All All
207/2.1/30 448/4.5/65
130 models All operating conditions
Front Rear
All All
310/3.1/45 448/4.5/65
Post #45115 13th Nov 2010 6:23am
Grockle
thanks for the replys, but have you got the tyre decal in your drivers door shut. 2.4 90 XS
Post #45122 13th Nov 2010 9:19am
Lorryman100
Quote:
Tyre pressures
Not on mine either, or any of the other door shuts. Just checked Thumbs Up
Post #45127 13th Nov 2010 10:11am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Rolling with laughter Rolling with laughter Rolling with laughter I love it!! You guys are so funny sometimes... www.ralton.co.za
Post #45410 16th Nov 2010 7:54am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Yes, but mine is an Australian spec 110. I think one of our silly Australia Design Rules for vehicles says that all new cars must have a tyre placard.
Does that help? Rolling Eyes
Rolling with laughter Rolling with laughter 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #45437 16th Nov 2010 12:56pm
Grockle
get me one please Derek but for a 90,thanks mate Thumbs Up 2.4 90 XS
Post #45438 16th Nov 2010 1:06pm
dm_td5
I'll take a picture for you to print and tape to the door Laughing 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #45512 17th Nov 2010 9:19am
Grockle
I've just rung my dealer, (Useless L/R Dealers Ltd) told them about the Aus spec having the sticker and low and behold they found it .
hold on that was for a Range Rover Sport,see what I mean Twisted Evil 2.4 90 XS
Post #45528 17th Nov 2010 10:22am
