![]() | Home > Wheels & Tyres > Tyre pressures |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Just in the manual I think.
30PSI front, 48 rear unloaded for a 110. Not sure for a 90. Defender 110XS SW gone... now VW California 180 4 Motion. |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Pressures in manual.
30psi Front, 38psi Rear unloaded - 90 |
i run mine at 30 f 35 r on road, take off 5 psi for offroad
draymond Member Since: 07 Apr 2009 Location: Sydney Posts: 49 ![]() ![]() ![]() |
I've got a placard, here in Aus.
It's inside the drivers door, but I can't remember if it's on the B Pillar or door itself? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Hi
Just checked my manual and it says the following. what about 235's - should it be at 35 or 38? Model - Tire size Front Rear 90 - 205/80 R16 1,9 bar 2,6 bar 28 lbf/in! 38 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! 90 - 265/75 R16 1,9 bar 2,4 bar 28 lbf/in! 35 lbf/in! 2,0 kgf/cm! 2,7 kgf/cm! BM52 |
Extract from Handbook.
http://topix.landrover.jlrext.com/topix/se...5962/index Production options weight The combined weight of options installed which weigh in excess of 1.4 kg (3 lb) more than the standard items that they replaced, and are not already considered in kerb or accessory weights. Items such as heavy duty brakes, high capacity battery, special trim etc. Vehicle capacity weight The number of seats multiplied by 68 kg (150 lb) plus the rated amount of load/luggage. Maximum loaded vehicle weight The sum of kerb weight, accessory weight, vehicle capacity weight, plus any production option weights. Rim The metal support for a tyre, or tyre and tube, upon which the tyre beads are seated. Tyre pressures Bead The inner edge of a tyre that is shaped to fit to the rim and form an air tight seal. The bead is constructed of steel wires which are wrapped, or reinforced, by the ply cords. TECHNICAL SPECIFICATIONS Wheel specifications Wheel type Wheel size Tyre size Alloy 7.0J x 16 235/85 R 16 Steel 6.5J x 16 7.50 R16C 7.50 R16 Steel 6JK x 16 205/80 R 16 Steel 5.5F x 16 7.50 R16C 7.50 R16 Steel 5.5J x 16 205/80 R 16 7.50 R16 Loading conditions Tyre size Pressure KPa/bar/psi 90 models All operating conditions. Front Rear All All 207/2.1/30 262/2.6/38 110 models Normal conditions Front Rear All All 207/2.1/30 331/3.3/48 110 models Vehicle loaded to gross maximum weight, and/or when towing Front Rear All All 207/2.1/30 448/4.5/65 130 models All operating conditions Front Rear All All 310/3.1/45 448/4.5/65 |
thanks for the replys, but have you got the tyre decal in your drivers door shut. 2.4 90 XS
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Not on mine either, or any of the other door shuts. Just checked ![]() |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Yes, but mine is an Australian spec 110. I think one of our silly Australia Design Rules for vehicles says that all new cars must have a tyre placard. Does that help? ![]() ![]() ![]() 110 300Tdi ![]() LROCV ::: AULRO.com |
get me one please Derek but for a 90,thanks mate ![]() 1968 1/32 scale Britains 109 Pick up. |
I've just rung my dealer, (Useless L/R Dealers Ltd) told them about the Aus spec having the sticker and low and behold they found it . hold on that was for a Range Rover Sport,see what I mean ![]() 1968 1/32 scale Britains 109 Pick up. |
