Home > Technical > Headlight levelling switch ?
Telshe
England 2004 Defender 90 Td5 XS CSW Cairns Blue
i came home last night with lights on dipped and thought l would see if the headlight leveller switch was working. Lo and behold there was no movement. I think l heard somewhere that they must only fitted if you have the high intensive beams. Would that be so with mine not working. I have the old filament bulbs.my defender is a 04 XS90. Your thoughts would appreciated.
Telshe
Post #450849 31st Aug 2015 3:19pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Mine worked with the standard bulbs, have you checked the fuses? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #450851 31st Aug 2015 3:28pm
Telshe
Man y thanks Richard for the quick reply. Will check tomorrow.
Regards Telshe
Post #450857 31st Aug 2015 3:55pm
landroverdiver
Check the adjusters are there and have power. I fitted new headlight bowls last year to get through the MOT, and ended up buying ones that were incompatible with the adjusters. I took them off and achieved an MOT pass. It's done with the adjuster at 0 setting.
One of these days I will get the proper bits and put things back together.
May seem obvious, but worth checking
Post #450880 31st Aug 2015 5:03pm
Happyoldgit
If the adjuster motors etc are present but have not been used for a long time they do have a tendency to sieze. Steve.
http://forums.lr4x4.com
Post #450884 31st Aug 2015 5:19pm
Telshe
Headlight levelling
That you for replays but it seems l have had a senior moment. They do work but very slow to the ones on my other car. Thanks for you replays.
Terry
Post #450927 31st Aug 2015 7:35pm
