Home > Maintenance & Modifications > Compressor position (re air lockers)
BigMike
Those of you with an airlocker(s), where did you fit the compressor?
Post #44693 8th Nov 2010 9:08pm
leeds
On our red 110 (300 TDi) the ARB air locker compressor is under drivers seat. Keeps it clean and dry
OK Pumas have more electrics in driver seat box but still should have room for compressor.
HTH
Brendan
Post #44696 8th Nov 2010 9:45pm
BigMike
actually there will be room in there. At the moment I keep my manual / book in there so there is definitely room for a small compressor. an excellent idea. I'm still interested in where others keep theirs but that seems to be a really good position, cheers.
Post #44698 8th Nov 2010 9:48pm
MK
Under the left wing (in my case LHD). Been for over a year there and no probs so far. Been on very dusty and wet conditions. If you are interested I can share a pic. Puma 110" SW
Post #44720 9th Nov 2010 10:17am
BigMike
That'd be great MK. Under the wing? Presumably in some kind of protective box?
Post #44793 9th Nov 2010 7:21pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
I've got mine under the RH wing (right hand drive), breather pipe runs inside the snorkel also on the RHS. It's a heavy duty ARB type so having access to the additional pressure port for tyre inflation is useful - although this could be mounted remotely with a length of pipe from a unit mounted anywhere.
When discussing the mounting location with guys at Devon4x4 they had some concerns about "oil misting" if the unit is put inside the truck - not sure if this was specifically to do with just a film of oil building up or whether there was a wider health and safety issue - either way the ultimate location made good use of a bit of the truck that would not be used for much else.....only other thought I had would have been whether the under wing space would be better used for a Eberspacher heater or similar - cross that bridge when I get a bit closer to going to the artic - which is a few years off yet
Locker switches are mounted in a column on the dashboard vertical close to drivers left hand
So far I've had no problems but not done a really deep wade with it in place. The unit is not boxed in in any way
Post #44820 9th Nov 2010 9:47pm
BigMike
I think oil misting can happen if the axle breathers get jammed up causing oil to go back up the pipe and into the compressor. Otherwise, shoudnt happen.
On my offisde rear wing I have an extended fuel tank but I guess I could use the left rear. I'd want it in a box though as I get into some deep water at times, not to mention mud.
I plan to put the switches on the front slope of the (new) cubby box.
I saw a 90 today (not a puma) with an eberspacher mounted directly behind the cubby box. looked neat, but very bulky.
Post #44824 9th Nov 2010 10:29pm
MK
The tin is at the stealer these days so I can not provide pics. But, anyway I would not fit the switches on the cubby box. I did it and not a good idea. Puma 110" SW
Post #44831 9th Nov 2010 10:53pm
BigMike
why's that?
Post #44832 9th Nov 2010 10:54pm
MK
You can push them accidentally and they reflect on the windshield. Moved them beside the steering column.
In a day or two I can post some pics. Puma 110" SW
Post #44835 9th Nov 2010 11:18pm
jst
mines in a rear locker in the back of the truck cab. best place is out of the elements but ideally not in side the passenger compartment.
If an O ring goes on the locker you can also get ep90 coming up the airline. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #44919 10th Nov 2010 10:17pm
MK
 Puma 110" SW
Post #45055 12th Nov 2010 3:36pm
BigMike
looks cool. whats the plate holding the switches and how did you fix it? (thanks for posting the pics by the way)
Post #45062 12th Nov 2010 4:26pm
leeds
This page HERE might be of interest to you Mike
Brendan
Post #45074 12th Nov 2010 5:47pm
BigMike
Cheers Brendan. I have the switches already, I'm just pondering on where to mount them
Post #45078 12th Nov 2010 6:09pm
