Home > 130 > 130 - new to me
Page 3 of 3 <123
65psi is the inflation pressure recommended for maximum load so if you are not running with load then I'd knock them back quite a bit. The wear pattern you have does suggest they are over inflated.
Same tyres and rims fitted to my DCPU and they are run at 30psi front & 48psi rear.
Post #450553 30th Aug 2015 9:58am
Page 3 of 3 <123
