Home > Maintenance & Modifications > Removable DLR cable connector to bumper |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
I am looking of a cable fitting that will allow me to connect to my bumpers DRL's that is robust, removable and waterproof (wading etc). Loads of ideas in the tinter web but I know there are some very experienced people on the forum so thought I would ask for advice.
I would prefer that the end connected to the bumper is mounted and so is secure but am open to advice from you lot Some initial thoughts are like these: http://www.ebay.co.uk/itm/WD19-Plug-Socket...2349a6e429 (not IP rated but is securely mounted) http://www.ebay.co.uk/itm/Yamitsu-Aquasafe...33a6f564e1 Cheers Steve |
26th Aug 2015 7:23am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17338 |
I usually use the Bulgin Buccaneer series of connectors for that sort of application (I've been using them for winch remote lead connectors for years), they're robust, waterproof, easy to assemble, and very modular. There are are male and female backshells, the connector parts of either gender can be panel or line mounted. They are available with three pins upwards to loads of pins.
See here for a three pole male line mounted plug, and here for a female panel mount connector. |
26th Aug 2015 8:02am |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 499 |
I was just about to post and recommend the Bulgin Buccaneer connectors
Bulgin Buccaneer - http://www.bulgin.co.uk/Products/Buccaneer/BuccaneerStandard.html * IP68 rating tested at 1.054kg/sq cm (15lb/sq in) 10m depth for 2 weeks and 9.84kg/sq cm (140lb/sq in) 100m depth for 12 hours * Water and dust proof to IP68 when mated * 2, 3, 4, 6, 7, 9, 12 and 25 pole * 12A, 277V ac/dc 2 pole screw terminal, 3 pole screw terminal and crimp contacts * 10A, 277V ac/dc 4 pole screw terminal * 5A, 277V ac/dc 6 and 7 pole screw terminal * 5A, 150V ac/dc 9 pole crimp contacts * 5A, 50V ac/dc 12 pole crimp and solder contacts * 1A, 50V ac/dc 25 pole crimp and solder contacts * BNC versions 50Ω and 75Ω * Plug or socket connection in each body style * Compact design * Diameter over coupling ring 38mm * Sealing caps available to maintain IP68 rating of unmated connectors * 7 body styles - flex cable, in-line flex cable, panel mount (front), panel mount (rear), PCB mount, bulkhead and flange mount They're available from CPC, Farnell and RS. I've had Bulgin Buccaneer 2-Way Connectors on my 110, used for the Rear Worklamps and Power Sockets, since I bought it new in 1989 - Click image to enlarge Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
26th Aug 2015 8:33am |
Thanks very much guys, I will order those now!
26th Aug 2015 8:37am |
