Home > Technical > What's this drip?
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
What's this drip?
I returned to the Landy today to find water dripping from underneath....I got under and it appeared to be coming from the gearbox(??) housing or maybe above it? It was roughly underneath the gearstick, maybe slightly behind. What water is there? It was a hot day, air con had been on and the car had been stood for twenty mins while I was in a shop. There was about a third of a cup full underneath on the Tarmac........should I be worried???
Post #448389 22nd Aug 2015 10:12pm
Johnnyboxer
Aircon condensing, more than likely
Post #448391 22nd Aug 2015 10:23pm
nitram17
Re: What's this drip?
[quote="Jonno1968"]I returned to the Landy today to find water dripping from underneath....I got under and it appeared to be coming from the gearbox(??) housing or maybe above it? It was roughly underneath the gearstick, maybe slightly behind. What water is there? It was a hot day, air con had been on and the car had been stood for twenty mins while I was in a shop. There was about a third of a cup full underneath on the Tarmac........should I be worried???[/quot
Mine does the same !there is alot of fluid and the drain is in a stupid place ...just make sure its not oil then it must be the aircon!
Post #448392 22nd Aug 2015 10:30pm
andrewlandy
Austria 2016 Defender 110 Puma 2.2 USW Alpine White
bump
Anyone seeing similar issues. I had this exact problem today?
Post #552399 30th Jul 2016 5:08pm
VeeTee
Netherlands
Probably condensing water coming from the A/C drain pipe. Land Rover in all their wishdom situated the drain above the gearbox... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #552428 30th Jul 2016 6:02pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Yes mine does it sometimes after using the aircon.
Post #552430 30th Jul 2016 6:11pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Same here, aircon. D4 does it as well Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #552432 30th Jul 2016 6:13pm
Retroanaconda
All vehicles with aircon do it. You just notice it more on a Defender because the higher ground clearance means you see the puddle.
Post #552440 30th Jul 2016 6:47pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I'm in Spain at the moment and every time I park up I come back to find the puddle, nothing to worry about even though SWMBO sees it as a sign of impending doom ( her 90 doesn't have a/c Rolling with laughter ) 2010 Defender 110 Station Wagon, Santorini Black.
Post #552451 30th Jul 2016 7:39pm
agentmulder
Kuwait
^^exactly.
Me ladies BMW does it too... Solved the bowel problem, working on the consonants...
Post #552531 31st Jul 2016 6:04am
Lew-M
England 2012 Defender 90 Puma 2.2 HT Keswick Green
Definitely the air con, the evoques I work on in plant have a habit of dumping upto a litre sometimes once the Aircon has been on!Alarming the first time you see it! Thumbs Up
Post #552632 31st Jul 2016 4:34pm
bear100
100% aircon! My defender, Range Rover, Audi and transporter does it. 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #552648 31st Jul 2016 5:35pm
sako243
My Defender doesn't do this...
Wait what's air con? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #552668 31st Jul 2016 6:57pm
mk1collector
The wife's puma with aircon does it, my td5 without aircon just dumps oil Mr. Green Ray
My build thread
Post #552673 31st Jul 2016 7:07pm
andrewlandy
Thumbs Up thanks
Post #552676 31st Jul 2016 7:15pm
