Home > Technical > Removing LT77 Gearbox
Mike.s
Hi,
I`m replacing the gearbox on my 200 Tdi. I`ve read the workshop manuald and it says to remove it, i have to disconnect all the front fan housing and radiator connections on the front of the engine.
I guess this is to to enable it tilt back so you can slide the gearbox off the engine with the gearbox clearing the body work.
I know the workshop manuals are a bit over zealous sometimes in their steps.
I`m borrowing an engine crane from a friend and plan on dropping the gearbox and transfer box together on to the floor/jack then pulling them out.
Do i really have to remove all the front bits off the engine or is not too bad really?
Cheers, Mike
Post #447104 18th Aug 2015 2:06pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
From my memories of doing this to my own 200tdi defender when working on the drive I am sure I only removed the viscous fan from the front end to stop it hitting the cowling. Hoses should be fine. I also have a vague memory of the transfer lever or gear lever stub being a pain to get past the seatbox (transmission tunnel out obviously) but can't remember if it is necessary to remove the selector housing before removing the boxes?
Post #447106 18th Aug 2015 2:12pm
NickMc
No need to at all. Take the fan off if you're worried or something under the flywheel housing to stop it drooping down.
Post #447236 18th Aug 2015 10:51pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Keep up the good work Mike.....it will soon be good as new Wink
I could do with your welding skills on the latest yoke I bought.....
Nigel.
Post #447245 19th Aug 2015 4:51am
Mike.s
Cool - hopefully, i`ll get away with just removing the floor and gearbox tunnel to gain access Smile
Cheers Nidge - getting there - truck is used pretty much everyday. I was putting up with the crunchy 3rd gear and double declutching it, but have been keeping an eye out for a 2nd hand one for a while. Picked one up this week which was a recon fitted to an ex mod 110 which has a slightly lower 1st and 2nd gear - will hopefully pull away a bit quicker with the disco transfer box and my big wheels. I`ve also had it tuned up by a guy who loves his diesels and it really flys now Smile
Should update my thread really!
Post #447270 19th Aug 2015 7:26am
shaggydog
I would definitely be interested to hear about that Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #447298 19th Aug 2015 9:02am
