Home > Technical > Dim Dip
Page 3 of 4 <1234>
ZeDefender
Thanks Andy Bow down
Wish I'd checked before fitting the LEDs (they don't work at all under-voltage Rolling Eyes )
However, I'm pretty sure I never had it from new Thumbs Up
Matt Tell someone you love them today because life is short.
Post #303998 1st Feb 2014 9:08am
Greannach
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Zermatt Silver
I'm glad I found this thread,
I was in the process of fitting my LED Headlights and wondered why the dipped beam was coming on when I switched my sidelights on. I figured that it was the dim-dip resistor causing the problem, but had no idea where it was. As described on this thread on my Puma DC110 its under the offside wing in front of the aerial.
I took the faux vent cover off and that gave me just enough working space to unplug it and secure it with a zip-tie. Problem's solved!
 Zermatt Silver 2.4 (with Alive stage 1 remap) TDCi 110 Double Cab Pick Up
Everything in life is somewhere else, and you get there in a Landrover.
Post #314514 8th Mar 2014 5:45pm
ZeDefender
WTF would we do without this forum?
Thumbs Up Tell someone you love them today because life is short.
Post #314520 8th Mar 2014 6:02pm
Anthony70
 2005 Defender 110 Td5 CSW Alveston Red
After four years it might be too late to resurrect this thread, but here goes...
For those cars that do not have dim-dip functionality, is it simply the resistor which is missing? Or are there other wires and/or relays involved?
Ant.
Post #446928 17th Aug 2015 8:01pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
There's an additional relay (R126) that lives behind the instrument binnacle, it provides the switching in/out of circuit of the 0.87Ω resistor and also the electronic logic to control it, with extra feeds from the lighting and ignition switches.
Post #446935 17th Aug 2015 8:13pm
need4speed
The dim-dip relay is the red one on the right hand side.
If your having trouble with it or want to do away with it, there is an official bypass unit available YWZ10003.
http://www.brit-car.co.uk/product.php?xProd=138745
Post #446979 18th Aug 2015 5:51am
Ant.
Unlike the TD5, on the Puma I think that the only difference is the presence/absence of the resistor,
The only useful thing I have ever found about having dim-dip (disconnecting the resistor was one of the first things I did on my Puma) is that when the inevitable happens and the light switch melts, you can short out the two wires to the resistor and the dip beam then comes on (full power) with sidelights. It is quite a handy get-you-home fix.
I can think of absolutely no other good points about the system at all, it was an idea conceived by morons, and removing the UK's ill-conceived requirement was one of the few good things that the EU has done for the British motorist!
(You can probably tell I have a low opinion of dim-dip!)
Post #447005 18th Aug 2015 8:17am
Clive
That's a very pricey shorting link Shocked
Post #447011 18th Aug 2015 8:35am
need4speed
I don't think it's just a shorting link though. And besides, a lot of people would short the incorrect terminals.... Laughing
Post #447028 18th Aug 2015 10:13am
Retroanaconda
It is just a link, inside the relay housing is literally just a small piece of metal that links the two terminals.
I bought one from Billing years ago and took it apart before fitting. A piece of wire does the same job, but the 'relay' is far neater Smile
Post #447250 19th Aug 2015 5:56am
shaggydog
Only a Land Rover owner would do that Rolling with laughter
Brilliant Smile Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #447304 19th Aug 2015 9:32am
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
And resurrecting this thread again .. we have an intermittent headlight problem - occasionally dipped headlights will just go out. At that point you can't switch them to full beam, but you can get them on full beam by pulling the stalk back.
Thinking to take a look at the dim dip relay and replace it, I took the dash apart but there was no sign of the same salmon pink relay. Are they fitted to later models? We have an 09MY 110 SW. 2009 110 XS Station Wagon
Post #590996 7th Jan 2017 3:36pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I have just had a problem where my headlights were on when switched off,they went off when I turned the ignition off though.
I Unplugged the red relay located behind the instrument binacle & shorted across the terminals fed by the red/blue wires with a short legnth of wire with spade conectors on either end.*
Problem sorted.
Thumbs Up
Marc
Post #591022 7th Jan 2017 5:18pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
That sounds a lot like the problem I had a few years ago with the indicator stalk/ flasher switch on the steering column. Turned out that the switch housing was slightly melting and the contacts were floating about. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #591023 7th Jan 2017 5:20pm
Wish I had knew about this thread years ago.
In the 7 years I've had my Puma 90 I never knew about this!
I do have it as when sidelights are on and engine running the headlights are lit but not as bright.
So I assume this is the dim, dipped one up and then full beam.
Only I didn't used to notice it on when I had OE Quadoptics but when I swapped to Crystals I seemed to get this dim / dip feature.
I'm fitting Noldens soon with Land Reigziger loom, shall I remove it or will it have no effect?
I'm tending to think with loom and LED's I'd get dipped beam on sidelights. (Due to resistor switching but bypassing resistor.)
Dipped as normal then main beam.
Obviously do not want dipped beam on with sidelights.
I'll have the sidelight loom fitted anyway, as the Noldens I've got are the position light type.
So I can see if I don't remove this resistor thing I'd have issues.
Very glad I've seen this, so thank-you to all that have info on this. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #591025 7th Jan 2017 5:38pm
Page 3 of 4 <1234>
