Home > Puma (Tdci) > Dci, not tdci anymore.
Page 2 of 2 <12
landy andy
Borrowed a turbo from a mate. He just happens to have a complete engine in bits in his shed, I suppose this is the advantage of such a crap engine, people will have spares. Whistle
Only been on little test run, but appears ok, had to flatten its face slightly, and change some of the bracketry.
Now need to decide long term what to do
Sell truck
Hybrid turbo and remap
Leave as is and monitor
Keep truck, but stop the long journeys in it
Get some rolling road time, to check engine and map.
But at least no work missed
Andy
Post #446680 17th Aug 2015 7:14am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
I'd say hybrid turbo. And let us know how it does long term, so I know what to do next year... 😄
Post #446682 17th Aug 2015 7:21am
K9F
The engine in mitigation is well proven, with many giving sterling service. I too have 'tinkered' and it has apart from the EGR Valve never missed a beat in 7 years. 'Tinkering' can often compromise the reliability as appears in this case perhaps?
landy andy wrote:
It was on tight, well as tight as you can get M8 nuts with a ring spanner.
Hybrid (if you've a grand lying about) or standard turbo, faces skimmed if possible and try to keep to any recommended torque figures.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446686 17th Aug 2015 7:38am
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Ouch!
Do you think it's related to the knocking noises you had recently?
I'm afraid mine will come out in pieces as well...
Post #446786 17th Aug 2015 1:33pm
landy andy
I don't think this is directly associated to the knocking, unless the knocking is the engine Incorrectly fuelling, making the engine raise the exhaust gas temperatures.
I think the main problem is that it's a poor quality undersized unit for the Defender. For many people who don't do high milage, and long runs it is fine, but ask it to drive at a constant motorway speed it chucks its dummy out. Plan at the moment is to monitor it and eventually get a second vehicle for the motorway/long drives.
Andy
Post #446931 17th Aug 2015 8:10pm
ericvv
^^ Myself 78k km, standard engine, so no tune, once in a while long highway drives of many hundreds of km at sustained 120 km speeds, possibly like this summer in very high ambient temps. Smooth as can be, why would these Ford Transit engines be unreliable? If you show a little respect and don't push the engine and its components, especially with a tune, don't think so.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #446960 17th Aug 2015 10:26pm
landy andy
48 thou miles is not many miles done yet.
I doubt mine will make it to the 168 thou miles my Td5 did.
Post #446964 17th Aug 2015 10:46pm
Page 2 of 2 <12
