Home > Puma (Tdci) > What pressure plate bolt, M8 x 13mm or M8 x 16mm? |
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 |
Land Rover say that the 6 pressure plate bolts should be changed also when clutch is replaced.
There are 2 different bolts; - URC 000030 that is M8 x 13mm - LR030000 that is M8 x 16mm My Defender is SALLDVBS87A741661, what is the correct part? I start to have all the parts; - clutch assembly - slave cylinder with thrust bearing - spigot bearing - transmission output shaft assembly - gearlever bushings Is here something else that should be changed while I'm there? (Gearbox and transfer box oil of course.) Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
17th Aug 2015 7:38pm |
